Asus H110M-PLUS D3 Intel H110 1151 Micro ATX DDR4 USB 3.1 HD
Reduced Price - Whilst Stocks Last
Quicklinx: BSTSWS00 Mfr#: H110M-PLUS
Industry-leading 5X Protection II employs the finest components, excellent circuit design, and exacting standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build - the result of decades of engineering experience from the world's leading motherboard brand.
With DDR4, you'll accelerate memory frequencies up to an incredible to 2133 MHz! And ASUS works with almost every DDR4 memory vendor, so you're assured the best compatibility.
With two USB 3.1 Type-A ports, you'll experience data-transfer speeds of up to 10 Gbit/s - or twice as fast USB 3.0. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further.
  • Advanced hardware safeguards
  • Make your memory go faster
  • Ultimate-speed 10 Gbit/s with two USB 3.1 onboard
  • Effortless PCI Express component removal
    The large winged clip is easy to reach and easy to operate. Just press the Q-Slot clip lightly, and graphics card just pop out. Installing or removing even the biggest graphics cards is no sweat.
  • Dedicated CPU and case fan controls
    Exclusive Fan Xpert ensures every fan achieves the best balance of cooling performance and low noise - and with the 100 series boards and their hardware-level 4-pin/3-pin PWM/DC mode for case fans, a simple BIOS adjustment lets you run your case fan in PWM/DC. Fan Xpert even includes Auto-Tuning mode to scan and detect all fan characteristics for single-click customization.
ASUS H110M-PLUS - motherboard - micro ATX - LGA1151 Socket - H110
Motherboard - micro ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
USB 3.0, USB 3.1 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887-VD2
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
RAID Features
Intel Rapid Storage Technology
2 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x HDMI , 2 x USB 3.1
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, Onboard LED, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Low EMI Solution, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard, USB 3.1 Boost, ASUS 5X Protection II, overvoltage protection
Software Included
Drivers & Utilities, ASUS AI Charger+, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
Plug and Play, ACPI 5.0
22.62 cm
18.55 cm
