Asus H110-PLUS Intel H110 S1151 DDR4 SATA 6Gb/s USB3.0 ATX
Quicklinx: BTY9WS00 Mfr#: H110-PLUS
Supreme ATX H110 with 5X Protection II for dependable stability, LED-illuminated audio shielding and DDR4 support.
ASUS H110-PLUS - motherboard - ATX - LGA1151 Socket - H110
Motherboard - ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
2 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x parallel
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, USB 3.0 Boost, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), Clear CMOS Button, ASUS Stainless Steel Back I/O, ASUS Fan Xpert 2+, LANGuard, ASUS 5X Protection II, overvoltage protection
I/O back plate
2 x Serial ATA cable
Software Included
ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
30.5 cm
19 cm
Limited warranty - 3 years
