The portable ROG GR6 has a console-inspired concept that redefines gaming as you know it. Enjoy the perfect combination of portability, the performance of a desktop PC, and the accessibility of a gaming console. With a sleek finish and detailing, the GR6 is a mean gaming machine that sits well in your bedroom or living room; in fact it's so compact you can even take it to LAN parties.
Quiet and cool gaming
ROG GR6 is perfect for your living room or bedroom. It features a dedicated cooling system with dual copper heat pipes and a large fan that direct heat away from the CPU and GPU for advanced cooling. -
SupremeFX audio
ROG GR6 features SupremeFX audio for immersive sound - Anti-EMI design, high-quality components, and audio utilities come together to give an added dimension to your gaming experience. -
Sonic Studio
Sonic Studio is an audio-tuning suite that provides an aural treat. Use the one-click Virtual Surround function to simulate 7.1 channel audio, through a stereo headset. It offers five superb audio controls, including Reverb, Bass Boost, Equalizer, Voice Clarity and Smart EQ - ensuring that everything you hear sounds just amazing! -
Scan and detect to dominate
Sonic Radar II helps you detect opponents through an on-screen overlay that shows the relative position of gunshots, footsteps and other sound effects.
- ASUS ROG GR6 R014R - SFF - Core i5 5200U 2.2 GHz - 8 GB - HDD 1 TB
- Personal computer - small form factor
- Processor
- Intel Core i5 (5th Gen) 5200U / 2.2 GHz (2.7 GHz) (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Graphics Controller
- NVIDIA GeForce GTX 960M
- Video Memory
- 2 GB
- Gaming
- Audio Output
- 5.1 channel surround
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac
- OS Provided
- Windows 8.1
- Matte black
- 6 cm x 24.5 cm x 23.8 cm
- 1.284 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Small form factor
- Gaming
- Matte black
Processor / Chipset
- CPU
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
- Dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 2 GB
Audio Output
- Sound Output Mode
- DTS Connect, High Definition Audio
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- Internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin
- 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 2 x USB 2.0 (2 in front) , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 4 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack
- Theft/Intrusion Protection
- UL, VCCI, C-Tick, BSMI, CB, FCC
- Power adapter
- Power Provided
- 120 Watt
Operating System / Software
- OS Provided
- Windows 8.1
- ENERGY STAR Certified
- 6 cm
- 24.5 cm
- 23.8 cm
- 1.284 kg
