All-new graphics card with exclusive DirectCU II and 0dB fan technologies boosts game speed by up to 7.7%, and stays 58% cooler and 3X quieter than reference
Strix GTX 750 Ti OC, a new graphics cards powered by the NVIDIA® GeForce® GTX™ 750 Ti graphics-processing unit (GPU) and designed for players who like to game on the edge of instinct.
Taken from the ancient Roman and Greek word for owl, Strix is the brand name for the stunning new ASUS gaming-gear series. Strix means the keenest hearing and sharpest eyesight and the ability to feel the environment, enabling the player to detect and react to even the slightest movement. Strix means survival on the very edge of instinct. Strix is in gamers' blood, just as it is in ours.
Strix GTX 750 Ti OC is packed with exclusive ASUS technologies, including DirectCU II for cooler, quieter and faster performance for incredible action gaming, and 0dB-cooling technology for light gameplay in total silence and Blu-ray movie playback that's free from distracting background noise.
The new card also features exclusive ASUS Super Alloy Power components for enhanced durability and cooling, and GPU Tweak for overclocking and online streaming that's as simple as it is flexible.
Strix GTX 750 Ti OC is fitted with 2GB of high-speed GDDR5 video memory and races along at boosted speeds of up to 1202MHz.
Play in total silence, and 7.7% faster and 58% cooler than reference
Strix GTX 750 Ti OC is equipped with exclusive DirectCU II cooling technology. This innovative design puts highly-conductive 6mm copper cooling pipes in direct contact with a card's GPU, so heat is dissipated quickly and with extreme efficiency. The new card also benefits from a heat-sink that delivers a heat-dissipation area that's 190% larger than reference, allowing Strix GTX 750 Ti OC to perform 58% cooler and run three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise.
When playing at high-definition (HD) resolutions of up to 1920 x 1080 pixels, and in environmental temperatures of up to 50°C, the Strix GTX 750 Ti OC automatically stop its fan -- allowing gamers to enjoy titles like Counter-Strike Online in absolute (0dB) silence.
Built for durability, designed to perform
Strix GTX 750 Ti OC is built with Super Alloy Power components for enhanced durability and cooling. Solid-state capacitors, concrete-core chokes and hardened MOSFETs are all designed to withstand much greater stress thanks to the application of specially-formulated materials. Super Alloy Power technology also reduces power noise such as buzzing and increases a graphics card's longevity by up to two-and-a-half times (2.5X) greater than reference.
Strix GTX 750 Ti OC also includes GPU Tweak, an ASUS-exclusive tool that enables users to control GPU speeds, voltages and video-memory clock speeds in real time -- so overclocking is both easy and can be carried out with high confidence.
GPU Tweak's built-in streaming tool lets users share on-screen action over the internet in real time, meaning others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images.
- NVIDIA GeForce® GTX™ 750 Ti
- PCI Express® 3.0
- 2048MB (2GB) GDDR5 memory
- 1124MHz base clock speed
- 1202MHz boosted speed
- 5400MHz memory clock
- 128-bit memory interface
- 1 x Dual-link DVI-I output
- 1 x DisplayPort output
- 1 x HDMI output
Silent gaming
Exclusive DirectCU II cooling technology outperforms reference designs with direct-GPU contact copper heatpipes and larger dissipation area: this means performance that's cooler and quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with fan technology that lets you enjoy games like Counter-Strike Online in complete silence - because the fan stops completely when the GPU temperature remains below a set level. -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS STRIX-GTX750TI-OC-2GD5 - graphics card - GF GTX 750 Ti - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750 Ti
- Memory
- 2 GB GDDR5
- Core Clock
- 1124 MHz
- Boost Clock
- 1202 MHz
- CUDA Cores
- 640
- Effective Memory Clock
- 5.4 GHz
- Memory Interface
- 128-bit
- Interfaces Details
- DVI-I (dual link) , DisplayPort , HDMI
- 3.81 cm x 19.6 cm x 12.2 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1124 MHz
- Boost Clock
- 1202 MHz
- CUDA Cores
- 640
- Dual Fan Design, Super Alloy Power technology, ASUS DIGI+ VRM, NVIDIA G-Sync ready, GPU Tweak Streaming, ASUS DirectCU II with 0dB Fan Technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5.4 GHz
- Bus Width
- 128-bit
- 75 Watt
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3.81 cm
- 19.6 cm
- 12.2 cm
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
