Asus GeForce GTX 1080 TURBO 8GB GDDR5X PCIe3.0 Graphics Card
Quicklinx: C5FSWS00 Mfr#: TURBO-GTX1080-8G
ASUS Turbo GeForce® GTX 1080 graphics deliver the sweet spot of performance
Dual-ball Bearing Fan runs smoother by reducing friction, further improving 4X longer card lifespan and cooling efficiency.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
Customizable Backlit Logo gives your system a truly unique look with your own LED backlit logo design.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Perfect Your Build
ASUS Turbo GeForce® GTX 1080 comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences. ASUS Turbo GeForce® GTX 1080 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
ASUS TURBO-GTX1080-8G - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1607 MHz
Boost Clock
1733 MHz
CUDA Cores
2560
Memory Interface
256-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
OpenGL 4.5
3.81 cm x 26.67 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1733 MHz
CUDA Cores
2560
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Dual Slot Fan Cooler, Native HDMI, Nvidia SLI ready, Dual ball Bearing Fan, GPU Tweak Streaming, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5X SDRAM
Bus Width
256-bit
Additional Requirements
8 pin PCI Express power connector
225 Watt
Software Included
Display drivers, ASUS GPU Tweak II
3.81 cm
26.67 cm
11.12 cm
