ASUS Turbo GeForce® GTX 1080 graphics deliver the sweet spot of performance
Dual-ball Bearing Fan runs smoother by reducing friction, further improving 4X longer card lifespan and cooling efficiency.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
Customizable Backlit Logo gives your system a truly unique look with your own LED backlit logo design.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Perfect Your Build
ASUS Turbo GeForce® GTX 1080 comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences. ASUS Turbo GeForce® GTX 1080 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
- ASUS TURBO-GTX1080-8G - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1607 MHz
- Boost Clock
- 1733 MHz
- CUDA Cores
- 2560
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
- API Supported
- OpenGL 4.5
- 3.81 cm x 26.67 cm x 11.12 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1607 MHz
- Boost Clock
- 1733 MHz
- CUDA Cores
- 2560
- VR Ready
- Max Resolution
- 7680 x 4320
- API Supported
- OpenGL 4.5
- Dual Slot Fan Cooler, Native HDMI, Nvidia SLI ready, Dual ball Bearing Fan, GPU Tweak Streaming, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Bus Width
- 256-bit
- Additional Requirements
- 8 pin PCI Express power connector
- 225 Watt
- Software Included
- Display drivers, ASUS GPU Tweak II
- 3.81 cm
- 26.67 cm
- 11.12 cm
