ASUS TURBO GeForce GTX 1080 Ti comes equipped with a dual ball-bearing fan for a longer card lifespan and exclusive Auto-Extreme technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences.
Dual-ball bearing fan
The dual-ball bearing fan on ASUS TURBO GeForce GTX 1080 Ti lasts longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. -
ASUS graphics cards are produced, using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components, that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability. -
ASUS TURBO GeForce GTX 1080 Ti graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime, without having to swap cables. -
ASUS TURBO GeForce GTX 1080 Ti comes with an LED backlit ASUS logo, that you can swap with your own custom design for a truly unique look.
- ASUS TURBO-GTX1080TI-11G - graphics card - GF GTX 1080 Ti - 11 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080 Ti
- Memory
- 11 GB GDDR5X
- Core Clock
- 1480 MHz
- Boost Clock
- 1582 MHz
- CUDA Cores
- 3584
- Effective Memory Clock
- 11.01 GHz
- Memory Interface
- 352-bit
- Max Resolution
- 7680 x 4320
- 2 x HDMI , 2 x DisplayPort
- API Supported
- OpenGL 4.5
- 3.81 cm x 26.67 cm x 11.12 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1480 MHz
- Boost Clock
- 1582 MHz
- CUDA Cores
- 3584
- VR Ready
- Max Resolution
- 7680 x 4320
- API Supported
- OpenGL 4.5
- Native HDMI, Nvidia SLI ready, Dual ball Bearing Fan, NVIDIA G-Sync ready, GPU Tweak Streaming, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 11 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 11.01 GHz
- Bus Width
- 352-bit
- Additional Requirements
- 6-pin + 8-pin PCI Express power connectors
- Software Included
- Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II
- 3.81 cm
- 26.67 cm
- 11.12 cm
