Asus GeForce GTX 1060 DUAL 6GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C881WS00 Mfr#: DUAL-GTX1060-6G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
ASUS Dual GeForce® GTX 1060 graphics provide sweet spot performance
Patented Wing-Blade Fans for max air flow with 105% more air pressure.
Perfectly matched with ASUS X99-A II Overview motherboards for optimised style and performance.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Double the Performance
ASUS Dual GeForce® GTX 1060 comes equipped with Patented Wing-Blade Fans for max air flow with 105% more air pressure. While exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming. ASUS Dual GeForce® GTX 1060 is perfectly matched with your ASUS X99-A II motherboard!
I/O Ports Highlight
1 x Native DVI-D
2 x Native HDMI 2.0
2 x Native Display Port
Optimised Style and Performance
Perfectly matched with ASUS X99-A II motherboards
ASUS Dual GeForce® GTX 1060 graphics card and X99-A II motherboards share perfectly matching colour themes and are ready for Windows 10. Dual GeForce® GTX 1060 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
Max Air Flow with 105% More Air Pressure
A patented wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards.
Premium quality and best reliability
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
VR-Friendly HDMI Ports
Enjoy immersive virtual reality experience
ASUS Dual GeForce® GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
GPU Tweak II: Intuitive performance tweaking
Adjust clock speeds, voltages and fan speeds to tune your graphics card(s) exactly how you want to. Select between GPU Tweak’s Standard or Advanced modes depending on your level of experience.
XSplitGamecaster: Instant gameplay streaming
Now, you can also launch XSplit Gamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
  • Powered by NVIDIA® GeForce® GTX 1060
  • GeForce® GTX VR Ready - Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies.
  • NVIDIA® G-SYNC ready - Delivers the smoothest and fastest gaming experience by synchronizing display refresh rates to the GPU, eliminating screen tearing and minimizing display stutter and input lag.
  • PCIE 3.0
  • Double the performance
    ASUS Dual GeForce GTX 1060 comes equipped with Wing-Blade Fans for max air flow with more air pressure. While Auto-Extreme technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
  • Wing-Blade Fans
    Wing-Blade design delivers maximum air flow and significantly improved static pressure over the heat sink, while operating at 3X quieter volumes than reference cards.
  • Auto-Extreme technology with Super Alloy Power II
    ASUS graphics cards are produced using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • VR-friendly HDMI ports
    ASUS Dual GeForce GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
  • GeForce GTX VR ready
    Discover ultimate VR performance, extremely low latency, and Plug-and-Play compatibility with leading headsets - driven by NVIDIA VRWorks technologies.
  • NVIDIA G-Sync ready
    Delivers an extremely smooth and fast gaming experience by synchronizing display refresh rates to the GPU, eliminating screen tearing and minimizing display stutter and input lag.
ASUS DUAL-GTX1060-6G - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5
4.3 cm x 24.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
Dual Slot Fan Cooler, Native HDMI, Dual Fan Design, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Wing-Blade Fans, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
4.3 cm
24.2 cm
13 cm
