Product
Asus GeForce GT 730 902MHz 2GB PCI-E 2.0 HDMI LP w/ Bracket
Quicklinx: 9Z6JWS00 Mfr#: GT730-2GD5-BRK
  • High-Definition Multimedia Interface (HDMI)
Hurry, only 2 left in stock!
£64.43 ex VAT
£77.31 inc VAT
Express delivery Order within the next 21 hours for delivery on Friday
ASUS GT 730 delivers efficient multimedia and gaming performance
  • Dust-proof Fan design increases particle resistance and extends card lifespan by up to 25% longer than reference.
  • Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
  • Low profile graphics cards for HTPC and multimedia PCs support smooth 1280 x 1024 gaming and Blu-ray 3D. Brackets bundled for fast setup!
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played.
  • Dust-proof fan (25% longer graphics card lifespan)
    Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
  • Super alloy power (enhanced durability and cooling)
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS GT730-2GD5-BRK - graphics card - GF GT 730 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 730
2 GB GDDR5
Core Clock
902 MHz
CUDA Cores
384
Effective Memory Clock
5.01 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
VGA , DVI-D , HDMI
API Supported
DirectX 11
2.65 cm x 14.5 cm x 6.9 cm
Microsoft Certification
Compatible with Windows 7
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
902 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
VGA , DVI-D , HDMI
API Supported
DirectX 11
Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, Blu-Ray 3D Support, NVIDIA Adaptive Vertical Sync, UEFI BIOS, GPU Tweak Streaming, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.01 GHz
Bus Width
64-bit
2 low-profile brackets
Software Included
ASUS GPU Tweak
2.65 cm
14.5 cm
6.9 cm
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GT 730
Interface: PCI Express 2.0 x16
Memory Size: 2GB
Memory Size: 2GB
Digital Output: Digital Visual Interface (DVI)
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Asus
Price Range Ex VAT: 50 - 100
