Asus GeForce GT 730 700MHz 4GB PCI-Express 2.0 HDMI
Quicklinx: 9Q0QWS00 Mfr#: GT730-4GD3
  • High-Definition Multimedia Interface (HDMI)
GT 730 is the astonishing high-value graphics card from ASUS! Equipped with the GeForce GT 730 graphics-processing unit, ASUS GT730-4GD3 includes some brilliant technologies that you can get only from ASUS. It's equipped with the dust-proof fan and a card with exclusive Super Alloy Power components for superior stability. GT730-4GD3 also comes with the easy-to-use tuning tool, GPU Tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the internet in real time!
  • Raging Cool for the win
  • Enhanced durability and cooling
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS GT730-4GD3 - graphics card - GF GT 730 - 4 GB
Graphics card
Bus Type
PCI Express 2.0
Graphics Engine
NVIDIA GeForce GT 730
4 GB DDR3
Core Clock
700 MHz
CUDA Cores
96
Effective Memory Clock
1.1 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Interfaces Details
DVI-I (dual link) , VGA , HDMI
API Supported
DirectX 11
3 cm x 19.3 cm x 13 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
700 MHz
CUDA Cores
96
Max Resolution
2560 x 1600
Interfaces Details
API Supported
DirectX 11
Native HDMI, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
Size
4 GB
DDR3 SDRAM
Effective Clock Speed
1.1 GHz
Bus Width
128-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3 cm
19.3 cm
13 cm
9Q0Q C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
