GT 730 is the astonishing high-value graphics card from ASUS! Equipped with the GeForce GT 730 graphics-processing unit, ASUS GT730-4GD3 includes some brilliant technologies that you can get only from ASUS. It's equipped with the dust-proof fan and a card with exclusive Super Alloy Power components for superior stability. GT730-4GD3 also comes with the easy-to-use tuning tool, GPU Tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the internet in real time!
Raging Cool for the win
GT 730 is the astonishing high-value graphics card from ASUS! Equipped with the GeForce GT 730 graphics-processing unit, ASUS GT730-4GD3 includes some brilliant technologies that you can get only from ASUS. It's equipped with the dust-proof fan and a card with exclusive Super Alloy Power components for superior stability. GT730-4GD3 also comes with the easy-to-use tuning tool, GPU Tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the internet in real time! -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GT730-4GD3 - graphics card - GF GT 730 - 4 GB
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 4 GB DDR3
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Effective Memory Clock
- 1.1 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Interfaces Details
- DVI-I (dual link) , VGA , HDMI
- API Supported
- DirectX 11
- 3 cm x 19.3 cm x 13 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- Native HDMI, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
- Size
- 4 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.1 GHz
- Bus Width
- 128-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3 cm
- 19.3 cm
- 13 cm
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
