PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
The exclusive alloyed components helps boost performance by reducing power loss, enhancing durability and achieving cooler operation. The chokes' concrete core eliminates the buzz sound in full load while the capacitors assure a 50,000 hours lifespan - equivalent to 2.5 times longer than traditional capacitors. Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
Super alloy power
The exclusive alloyed components helps boost performance by reducing power loss, enhancing durability and achieving cooler operation. The chokes' concrete core eliminates the buzz sound in full load while the capacitors assure a 50,000 hours lifespan - equivalent to 2.5 times longer than traditional capacitors. -
Dust-proof fan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
Low profile design
Ideal for home theater PCs and multimedia centers with low profile design and high power efficiency. -
NVIDIA CUDA
Unlocks the power of GPU's processor cores to accelerate the most demanding system tasks. -
NVIDIA PhysX
Dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters. -
DirectX 11 done right
Brings new levels of visual realism to gaming on the PC and get top-notch performance.
- ASUS GT610-1GD3-L - graphics card - GF GT 610 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 610
- Memory
- 1 GB DDR3
- Core Clock
- 810 MHz
- Effective Memory Clock
- 1.2 GHz
- RAMDAC
- 400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- VGA , DVI-I (dual link) , HDMI
- API Supported
- DirectX 11
- 1.78 cm x 16.5 cm x 12.2 cm
- Microsoft Certification
- Compatible with Windows 7
- Bus Type
- Graphics Engine
- Core Clock
- 810 MHz
- RAMDAC
- 400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- ASUS 0-dB thermal solution, Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.2 GHz
- Bus Width
- 64-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 1.78 cm
- 16.5 cm
- 12.2 cm
