Asus GeForce GT 1030 OC 2GB GDDR5 PCIe 3.0 LP Graphics Card
Quicklinx: CWYCWS00 Mfr#: GT1030-SL-2G-BRK
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GT 1030
Interface: PCI Express 3.0
Memory Size: 2GB, 2GB
Hurry, only 1 left in stock!
£68.25 ex VAT
£81.90 inc VAT
ASUS GeForceĀ® GT 1030 2GB GDDR5 low profile graphics card for silent HTPC build (with I/O port brackets)
  • Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers.
  • AUTO-EXTREME Technology delivers premium quality and best reliability.
  • GPU Tweak II makes performance tweaking easier and more visual than ever with an intuitive, all-new UI.
ASUS GT1030-SL-2G-BRK - graphics card - GF GT 1030 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0
Graphics Engine
2 GB GDDR5
Core Clock
1266 MHz
Boost Clock
1506 MHz
CUDA Cores
384
Effective Memory Clock
6008 MHz
Memory Interface
64-bit
Max Resolution Details
DVI: 1920 x 1200
DVI-D (Single-Link) , HDMI
API Supported
DirectX 12, OpenGL 4.5
Fanless
4 cm x 17.3 cm x 6.9 cm
Graphics card - low profile - fanless
Bus Type
PCI Express 3.0
Graphics Engine
Core Clock
1266 MHz
Boost Clock
1506 MHz
CUDA Cores
384
DVI: 1920 x 1200
API Supported
Native HDMI, ASUS 0-dB thermal solution, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6008 MHz
Bus Width
64-bit
Software Included
Display drivers, ASUS GPU Tweak II
4 cm
17.3 cm
6.9 cm
Memory Size: 2GB
Memory Size: 2GB
Brand: Asus
Price Range Ex VAT: 50 - 100
