A gaming laptop should be powerful, reliable and packed full of the latest technology and innovations. That’s exactly what you’ve got in the stylish Asus G752, the latest ROG gaming laptop with Windows 10 operating system and a sixth generation Intel Skylake Core i7 processor.
The latest processor means that you have a highly powerful Asus gaming laptop that also features NVIDIA GeForce GTX graphics for the highest quality gaming and streaming quality.
The ROG G752 comes complete with a headset, mouse and gaming rucksack to give you everything you need to get started straightaway – wherever you are; and Asus have even taken steps to combat ghosting, a major issue for competitive gamers pressing multiple keys in short succession, with specially-developed anti-ghosting backlit keyboard so you can play in your chosen conditions.
You can play on and on thanks to the dedicated cooling modules designed to remove heat from the CPU and GPU, while the 8-cell Lithium Ion battery in this dedicated Asus gaming laptop ensures that you can keep gaming until your mission is complete.
Order your new Asus G752 gaming laptop online today.
The laptop for the discerning gamer
The ASUS ROG G series features bold, sleek lines with a stealthy matte brushed aluminum finish. An illuminated ROG logo proudly reflects its gaming heritage. A Full HD display with wide viewing angles gives you clear, crisp gaming visuals. -
Backlit chiclet keyboard with specially marked WASD keys
The G series sports a backlit chiclet keyboard with specially marked WASD gaming keys. The keys provide a solid typing feedback for an increased feel. You can adjust the backlight accordingly to suit dimmer gaming environments. -
Full HD IPS display for spectacular images
The G series features a Full HD IPS display with an anti-glare coating and wide viewing angles on both horizontal and vertical planes. This gives you high-definition gaming visuals with stunning detail and accurate colors for a truly immersive gaming experience. -
4K UHD-ready output with Trinity Display
The G series is also 4K UHD-ready thanks to Trinity Display. The G series provides 4K/UHD output and supports up to three external displays through HDMI and Mini DisplayPort for gaming, movies, or multitasking. -
Stable performance with a silent cooling system
The G series has been designed to withstand marathon gaming sessions, with a powerful thermal solution that ensures system stability in the heat of the action. It's silent too, so it won't distract you from your game. -
Fast data transfers with USB 3.0
USB 3.0 gives you fast data transfer speeds and ensures your mobile devices get charged faster too. -
Experience immersive in-game audio
The G series features SonicMaster Premium technology that provides you with high-quality sound.
- ASUS ROG G752VY-T7049T - 17.3" - Intel Core i7 - 6820HK - 32 GB RAM - 512 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6820HK / 2.7 GHz, up to 3.6 GHz / 8 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- Optical Drive
- Blu-ray
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 980M
- Gaming
- Input Device
- Mouse
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 8-cell
- 41.6 cm x 32.2 cm x 4.9 cm
- 4.3 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6820HK / 2.7 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 512 GB SSD M.2 PCIe
- Secondary Storage
- 1 TB HDD SATA 6Gb/s
- Optical Drive
- BD-ROM
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
Audio & Video
- Graphics Processor
- Gaming
- Camera
- Yes - VGA
- Image Sensor Type
- CMOS
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: ASUS SonicMaster, Nahimic sound technology
Input
- Mouse, keyboard, touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 8-cell Lithium Ion
- Capacity
- 88 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V, 11.8 A
Connections & Expansion
- Headphone output , Thunderbolt , HDMI , 4 x USB 3.0 , LAN , USB-C , Microphone input , Audio line-in
- Memory Card Reader
- Yes (SD Card)
- System password, hard drive password
- Included Accessories
- Power adapter, Gaming Mouse, Gaming Bag, headset
- 4.3 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
