From the critically-acclaimed Republic of Gamers (ROG) series of laptop PCs, the Asus G752VY is here to take your gaming experience to the next level. Its revolutionary design and high-quality performance make this Asus gaming laptop a true trailblazer.
Powered by an Intel Core i7 processor, the G752VY also delivers 24GB RAM and features 256GB SSD storage - so if you're looking for an exceptional gaming performance, you needn't look any further than this Asus notebook.
Its distinctive design is striking and instantly recognisable, with the G752VY finished in a stunning Armor Titanium and Plasma Copper colour scheme. There's a dust-release thermal fan to stop things from getting too heated, while the device's backlit anti-ghosting gaming keyboard provides 30-key rollover to give you exceptional gaming control when you need it.
Combined with its processing power and souped-up specs, the G752VY's NVIDIA GeForce GTX graphics provide smooth, quick and textured visuals.
For a no-nonsense gaming laptop, the Asus G752VY could be just the solution.
Unbeatable performance
ROG G752 gives you unbeatable performance thanks to its high-performance processor and graphics card - enjoy games at their highest settings, or play and broadcast live stream. -
Mobile 3D vapor chamber
Temperature uniformity vapor chamber is commonly used with high-performance, high voltage graphics cards to increase cooling efficiency. The ROG-exclusive Mobile 3D vapor chamber, together with the copper heat pipe, create an effective and efficient cooling system that helps boost GPU performance by up to 6 percent for smooth and stable gaming. -
Efficient dust-release thermal tunnel
The unique thermal design of ROG G752 helps prevent internal dust build-up. This exclusive design directs dust into the anti-dust tunnel to keep them away from internal components. This prolongs component lifespan and enhances overall stability of the laptop. -
Dedicated cooling modules for the CPU and GPU
ROG G752 has dedicated cooling modules for the CPU and GPU to effectively cool each component. Hot exhaust is efficiently managed and expelled through the rear vents to direct heat away from you for more comfortable gaming sessions. -
Backlit anti-ghosting keyboard with 30-key rollover
Anti-ghosting keys ensure your commands are instantaneously and correctly interpreted - even if you hit up to 30 keys simultaneously. And with more macro keys at your disposal, everything you need is at your fingertips.ROG G752 has ergonomically-designed keys with 2.5mm of key travel. This gives you responsive keystrokes when typing and entering commands - making it easy for you to dominate the battlefield. -
Intel Thunderbolt 3
Onboard Intel Thunderbolt technology gives you single-cable data and signal transmission rates of up to 20Gbits/s - twice the bandwidth of USB 3.1. ROG G752 gives you both Intel Thunderbolt and USB 3.1 Type-C for increased compatibility with your various devices.
- ASUS ROG G752VY-T7048T - 17.3" - Intel Core i7 - 6700HQ - 32 GB RAM - 256 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 256 GB SSD - NVMe + 1 TB HDD
- Optical Drive
- Blu-ray
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 980M
- Video Memory
- 4 GB GDDR5 SDRAM
- Gaming
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 8-cell
- 42.8 cm x 33.3 cm x 4.8 cm
- 4.6 kg
- Environmental Standards
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
- Secondary Storage
- 1 TB HDD SATA 6Gb/s
- Optical Drive
- BD-ROM
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- NVIDIA G-SYNC compatible
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Gaming
- Camera
- Yes - VGA
- Image Sensor Type
- CMOS
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
- Numeric Keypad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 8-cell Lithium Ion
- Capacity
- 88 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V, 11.8 A
Connections & Expansion
- Interfaces Details
- HDMI , 4 x USB 3.0 , LAN , USB-C Gen 2 (supports Thunderbolt 3) , Microphone input , Headphone/microphone combo jack , Mini DisplayPort
- Memory Card Reader
- Yes (SD Card, MultiMediaCard)
Software
- Software Included
- XSplit Gamecaster
- Included Accessories
- Power adapter, Gaming Mouse, Gaming Bag, headset
- 4.6 kg
Sustainability Information
- TCO Certified
