Introducing the ASUS ExpertBook B1 Packed with business-friendly features and power, ASUS ExpertBook B1 is the ideal choice for ambitious firms and inspirational educational institutions. With a compact design, a bright, clear 14-inch display for vibrant visuals, plus impressive performance, enterprise-level security, military-grade durability, and extensive connectivity, ExpertBook B1 is the perfect portable partner to empower your business.
Go-anywhere mobility
With a 14-inch, NanoEdge display, and 178° wide viewing angle, ExpertBook B1 enables superb viewing experiences for every scenario. The NanoEdge display keeps ExpertBook B1 compact so you can simply slip ExpertBook B1 into your backpack, and you'll be ready for a full day of performance anywhere. -
Great all-around performance
Enjoy heavy-duty performance on ExpertBook B1, with an advanced 12th Gen Intel Core processor, delivering the powerful performance you need to get the job done. Coupled with a large memory and capacious storage, ExpertBook B1 is the business laptop that equips you for even the most intensive work and ensures quick access to the content you need. It's also primed for non-stop connectivity, with congestion-busting Wi-Fi 6E for speedy stable connection. -
Fingerprint sensor
ExpertBook B1 has built-in biometric security, with a fingerprint sensor for easy access. So, just tap the button to log in - no difficult-to-remember passwords or PIN required! -
TPM 2.0
A discrete TPM 2.0 chip securely stores authentication information used by software, such as passwords or encryption keys, to protect important data and transactions. Your details remain encrypted, virtually eliminating the risk of leaks through hacking. -
IR camera
Speedy and secure facial login with IR camera, allowing you to get to work without lifting a finger. -
Webcam privacy shield
A physical cover obscures ExpertBook B1's webcam for an assurance of instant privacy when it's not in use. -
I/O ports
ExpertBook B1 is loaded with I/O ports for productivity enhancement. These include USB Type-A, USB Type-C, and an HDMI output, plus wired network connectivity with a unique MAC address for easy device management. -
Sustaining an incredible future
ASUS Expert Series merges the ASUS Design Thinking ethos with a sustainability technology to foster a circular future, achieving multiple internationally recognized environmental certifications. By embracing the goal to achieve net-zero, ASUS Expert series creates minimum waste and maximum efficiency - ensuring an exceptional quality for consumers and an ever-reducing impact on the environment.
- ASUS ExpertBook B1 B1402CBA-EBI5X - 14" - Intel Core i5 - 1235U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Pro
- Processor
- Intel Core i5 (12th Gen) - 1235U / 1.3 GHz, up to 4.4 GHz / 12 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" 1920 x 1080 / Full HD
- Graphics
- Intel Iris Xe Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Star black
- 32.69 cm x 21.45 cm x 1.99 cm
- 1.49 kg
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Gold
- Product Type
- Notebook
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core i5 (12th Gen) 1235U / 1.3 GHz
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 10-core
- Cache
- L3 - 12 MB
- Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 40 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
- 14"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 45% NTSC
- Anti-glare, WideView, NanoEdge display, 81% screen-to-body ratio
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- Privacy shutter, IR camera, Windows Hello
- Sound
- Speaker, array microphone
- Audio Features
- Output: Audio by Dirac
Input
- Keyboard, touchpad
- Spill-resistant, chiclet keyboard, 1.4mm travel distance
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Dual stream (2x2)
- Technology
- 3-cell Lithium Ion
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt, 20 V, 3.25 A
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (Power Delivery) , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , LAN , HDMI
- Star black
- Case Material
- Plastic
- Security
- Hard drive password, MIL-STD-810H tested, BIOS protection, Computrace ready from BIOS
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- USB-C power adapter
- RoHS, REACH, FSC Mix
- 1.49 kg
Sustainability Information
- TCO Certified
- - TCO Certified Notebooks 9
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
