Impossibly thin and exceptionally stylish, the ASUS Eee PC 1008HA 'Seashell' takes the Eee PC Series to dizzying new heights. With a design inspired by the sleek sculpted shape of a seashell, the 1008HA is no thicker than your finger and weighs a mere 1.1kg, making it the most powerful and portable Eee PC to date.
Elegant seashell inspired design
Seemingly crafted by nature itself, the Eee PC seashell draws its inspiration from seashells and its opalescent and glossy exterior is crafted by the innovative in-Mold Roller technology. It's so light and compact, you can take it anywhere with you! And with sleek curves and smooth lines hugging its lustrous shell, the Eee PC seashell will easily charm passers-by wherever it goes. -
Slim and lightweight
The Eee PC seashell is a highly portable companion that users can carry about. Boasting a profile measuring just 1-inch in depth and weighing at 1.1kg, the svelte and lightweight Eee PC seashell is a joy to behold and its compact dimensions make it the perfect runabout Internet device anywhere. The Eee PC seashell is built to be your perfect travel companion. -
6 hours battery life
With the exclusive ASUS Super Hybrid Engine's increased power efficiency, the Eee PC can deliver an impressively long battery lifespan - eliminating worries about power while on-the-go and easily keeps users connected for full day, unplugged computing. -
Multi-touch pad of easily zoom in/out
With the multi-touch gesture input feature, you can easily zoom in and out to view photos or read documents by just moving two fingertips apart or together on the touchpad. You can also simultaneously slide two fingertips up or down the touchpad - making scrolling in a window easy without the use of a mouse. -
Egonomic keyboard for unsurpassed comfort
Ergonomically designed keyboard for superior comfort. The Eee PC seashell's keyboard is more comfortable and less fatiguing to type on for prolonged periods. -
Easy communication with digital array mic and 1.3-megapixel camera
Communicate with anyone face-to-face, anytime and anywhere, with the built-in 1.3 megapixel webcam. With the digital array mic, which consists of two powerful microphones, ambient background noises are eliminated, as well as reduced echoes for clearer voice recording. -
Exclusive VGA dongle for clear image output
The Eee PC seashell comes with an exclusive VGA dongle that conceals away neatly at its base when not in use. With the VGA dongle, you'll be able to mirror whatever's on the Eee PC's screen on a larger screen - perfect for presentations and movie sessions!
- ASUS Eee PC 1008HA Seashell - 10" - Atom N280 - 1 GB RAM - 160 GB HDD
- Product Type
- Netbook
- Operating System
- Win XP Home
- Processor
- Intel Atom N280 / 1.66 GHz / 512 KB Cache
- Memory
- 1 GB DDR2 (1 x 1 GB)
- Storage
- 160 GB HDD / 5400 rpm
- Display
- 10" LED backlight 1024 x 600 / WSVGA
- Integrated Webcam
- Networking
- 802.11b/g/n (draft), Bluetooth 2.1 EDR, 10/100 Ethernet
- Midnight blue
- 26.2 cm x 17.8 cm x 2.6 cm
- 1.1 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 1 year
- Product Type
- Netbook
- Operating System
- Microsoft Windows XP Home Edition
Processor / Chipset
- CPU
- Cache
- 512 KB
- RAM
- 1 GB (1 x 1 GB)
- Max RAM Supported
- 2 GB
- Technology
- DDR2 SDRAM
- Speed
- 667 MHz / PC2-5300
- Rated Speed
- 667 MHz
- Form Factor
- SO-DIMM 200-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 160 GB HDD SATA 3Gb/s / 5400 rpm
Display
- 10"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1024 x 600 (WSVGA)
- Widescreen
Audio & Video
- Camera
- Resolution
- 1.3 Megapixel
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- Lithium polymer
AC Adapter
- Input
- AC 120/230 V (50 - 60 Hz)
Connections & Expansion
- Slots
- 1 x memory (0 free)
- 2 x USB 2.0 , VGA , Headphone output , Microphone input , LAN
- Midnight blue
- Cables Included
- Mini-VGA-VGA adapter
- 1.1 kg
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
