Smart performance
Powered by the Intel Celeron quad-core 2 GHz SoC processor, significantly faster and more efficient than the previous Intel Celeron processors, EB1036 delivers easy multitasking and enhanced performance. -
Front USB 3.0
USB 3.0 transfers data 10x faster than USB 2.0 while maintaining complete backward compatibility. The EB1036 features front USB 3.0 ports, allowing you to transfer data with ultimate speed and ease. It delivers data transfer rates up to 6 Gb/s each. -
Built-in COM ports
On board COM port provides the elasticity for peripheral devices, including bar code scanners, printers, LED text displays, etc. -
Dual display functionality
The EeeBox PCs feature D-sub and HDMI output ports with dual display support. On two separate screens make you more productive. -
Sleek and clean design
The ASUS EeeBox features a sleek design and extremely lightweight. ASUS EeeBox is simple, chic, and even thinner than a book! -
Easily set up password protection for your data with UEFI BIOS
UEFI BIOS not only provides a mouse-controlled interface that enables more flexible and convenient input, but also combines system management tools like HDD password protection and I/O port activation. A user-friendly graphics-based BIOS interface offers easier system tweaking and greater storage support. -
Kensington lock slot
ASUS commercial desktops come with a Kensington lock for additional asset management and security. Keeping your hardware and confidential data inside well protected. -
F9 one key recovery
The F9 key allows you to use the recovery partition to restore your PC to its original working state. -
ASUS secure delete
An easy-to-use interface that allows you to permanently remove confidential data from the recycle bin. Simply launch secure delete and drag and drop the files to be deleted. -
Preserves the environment, also lowers operating costs
The energy-efficient ASUS EeeBOX PCs EB1036 protect the environment while helping lower businesses' operating costs. These eco-friendly workstations are recipients of some of the industry's highest environmental certifications including ENERGY STAR. -
Consumes 70% less power than a desktop
ASUS EeeBox PC EB1036 requires less energy than traditional PCs up to 70%, boosting system performance when handling demanding tasks and lowering consumption when less power is needed.
- ASUS Eee Box EB1036 - mini desktop PC - Celeron J1900 2 GHz - 4 GB - HDD 500 GB
- Personal computer - mini desktop PC
- Processor
- Intel Celeron J1900 / 2 GHz (, up to 2.42 GHz, (Quad-Core)
- Processor Socket
- LGA1170 Socket
- Cache Memory
- 2 MB
- Cache Per Processor
- 2 MB
- RAM
- 4 GB (installed) / 8 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA
- Optical Storage
- No optical drive
- Card Reader
- 4 in 1
- Graphics Controller
- Intel HD Graphics
- Networking
- GigE, 802.11b/g/n
- OS Provided
- No operating system
- Black
- 2.9 cm x 21.9 cm x 17.25 cm
- 690 g
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- Mini desktop PC
- Built-in Devices
- Antenna
- Black
Processor / Chipset
- CPU
- Clock Speed
- 2 GHz
- Max Turbo Speed
- 2.42 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1170 Socket
- Chipset Type
- Mobile Intel HM70 Express
Cache Memory
- Installed Size
- 2 MB
- 2 MB
RAM
- Installed Size
- 4 GB / 8 GB (max)
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
Audio Output
- High Definition Audio
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Wi-Fi CERTIFIED
- Slots
- SO-DIMM 204-pin
- 1 x LAN (Gigabit Ethernet) , 3 x USB 2.0 (3 in front) , 1 x USB 3.0 (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x headphones - mini-jack (1 in front) , 1 x VGA output , 1 x HDMI , 1 x serial
- Theft/Intrusion Protection
- CSA, UL, C-Tick, BSMI, CB, CCC, FCC, CECP
- Power adapter
- Power Provided
- 45 Watt
- Power Consumption Stand by
- 6.695 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 2.9 cm
- 21.9 cm
- 17.25 cm
- 690 g
