Powered by the next generation Intel Celeron Processor N2807 are significantly faster and more efficient. They deliver easy multitasking and enhanced performance. The EeeBox PCs feature D-sub and HDMI output ports with dual display support. On two separate screens make you more productive. The ASUS EeeBox features a sleek design and extremely light weight. ASUS EeeBox is simple, chic, and even thinner than a book!
Fan-less design: Enjoy a silent working environment, increased system reliability, and save on energy costs.
1-liter sized chassis with rotatable VESA-mount to maximize workspaces and placement flexibility.
Long life cycle (> 3 years).
Windows OS allows you to create customized intelligent solutions to your business requirements.
Full compatibility with a wide range of business peripherals; features a 4-in-1 card reader, USB3.0, USB2.0, HDMI, VGA, and COM ports.
Smart performance
Powered by the next generation Intel Celeron Processor N2807 are significantly faster and more efficient. They deliver easy multitasking and enhanced performance. -
Easy connectivity with front USB 3.0 ports
USB 3.0 transfers data ten times faster than USB 2.0 while maintaining complete backward compatibility. E210 features two front USB 3.0 ports and three USB 2.0 on the rear I/O panel, allowing you to transfer data with ultimate speed and ease. -
Built-in COM ports
On board COM port provides the elasticity for peripheral devices, including bar code scanners, printers, LED text displays, etc. -
Dual display functionality
The EeeBox PCs feature D-sub and HDMI output ports with dual display support. On two separate screens make you more productive. -
Sleek and clean design
The ASUS EeeBox features a sleek design and extremely light weight. ASUS EeeBox is simple, chic, and even thinner than a book! -
Rotatable VESA-mount
Rotatable VESA-mount kit is designed to provide user the flexible placement with easy I/O ports access. You don't need to turn the monitor around & you still easily use the function of rotation to find the port you would like to use. -
Fan-less design
The model features a fan-less design, giving users a quiet work space by eliminating the ambient noises caused by internal fans. This approach also decreases power consumption, and improves system reliability by avoiding potential dirt-related component failures.
- ASUS Eee Box E210 - mini PC - Celeron N2807 1.58 GHz - 2 GB - SSD 32 GB
- Thin client - mini PC
- Processor
- 1 x Intel Celeron N2807 / 1.58 GHz (, up to 2.16 GHz, (Dual-Core)
- Cache Memory
- 1 MB
- Cache Per Processor
- 1 MB
- RAM
- 2 GB (installed) / 4 GB (max) - DDR3L SDRAM
- Hard Drive
- SSD 32 GB
- Optical Storage
- No optical drive
- Card Reader
- 4 in 1
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo
- Networking
- GigE, 802.11b/g/n
- OS Provided
- Microsoft Windows Embedded Standard 7 64-bit
- Black
- 2.9 cm x 17.25 cm x 21.9 cm
- 690 g
- Environmental Standards
- ENERGY STAR Qualified
- Thin client
- Product Form Factor
- Mini PC
- Built-in Devices
- Antenna
- Black
Processor / Chipset
- CPU
- Intel Celeron N2807
- Clock Speed
- 1.58 GHz
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 1 MB
- 1 MB
RAM
- Installed Size
- 2 GB / 4 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 1 (Total) / 0 (empty)
- Configuration Features
- 1 x 2 GB
Hard Drive
- SSD
- Capacity
- 1 x 32 GB
Optical Storage
- No optical drive
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Slots
- 1 (total) / 0 (free) x SO-DIMM 204-pin
- 3 x USB 2.0 (3 in front) , 1 x USB 3.0 (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x headphones - mini-jack (1 in front) , 1 x VGA output , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x serial
- Included Accessories
- Vertical stand, VESA mounting kit
- Theft/Intrusion Protection
- VESA Mounting Interface
- CSA, UL, BSMI, CB, FCC
- Power adapter
- Power Consumption Stand by
- 6.36 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 2.9 cm
- 17.25 cm
- 21.9 cm
- 690 g
