Asus D310MT-I34170027F Intel Core i3-4170 4GB 500GB Win 8.1 Pro
Quicklinx: BYYRWS00 Mfr#: D310MT-I34170027F
  • Core i3
  • Windows 8.1 Pro
ASUSPRO Series desktops empower easy multitasking with powerful processors, powerful graphics to best handle your workload. D510MT features a modular design that offers more flexible support for hard drives, RAM, PCI cards, and USB devices - ideal for ever-expanding businesses. The serial and parallel ports are both default on back I/O, freeing up PCI slots for additional upgrades.
  • Smart performance
  • Rich I/O ports for your peripherals
  • Easy connectivity with front USB 3.0 ports
    USB 3.0 transfers data 10X faster than USB 2.0 while maintaining complete backward compatibility. D510MT features two front USB 3.0 ports, allowing you to transfer data with ultimate speed and ease. Support two SATAIII, delivering data transfer rates of up to 6Gb/s each.
  • Tool-less chassis access for easy upgrade and maintenance
    D510MT features front-facing vents, a top-front power button, user friendly USB ports on the top of the front bezel, a HDD indicator and an easy-access design for maintenance and upgrades.
  • F9 one key recovery
    The F9 key allows you to use the recovery partition to restore your PC to its original working state. (Copying your data files and making note of any customized configuration settings before using the system recovery partition is required.
  • ASUS business manager
    ASUS Business Manager is a set of program utilities for performing maintenance and optimization tasks to PCs. This software package features a one-page interface to access system monitoring tools, BIOS updates, USB Blocker data movement controls, and energy-saving controllers.
  • Optimized user friendly BIOS interface
    Based on UEFI (Unified Extensible Firmware Interface), ASUSPRO commercial desktops provides a user friendly BIOS interface. The simple graphic and mouse controlled interface makes changing BIOS settings much more faster and easier, helping MIS reduce efforts of maintenance.
  • Kensington lock slot and padlock slot
    ASUS commercial desktops come with a Kensington lock and padlock slot for additional asset management and security. Keeping your hardware and confidential data inside well protected.
  • Easily set up password protection to prevent unauthorized access
    AI Security software management tool protects your data from unauthorized access and computer viruses. It restricts users' access to confidential data, including enabling or disabling external USB devices or optical drives' data writing or reading capabilities, also reduces the chances of incursions from viruses.
  • Data protection with ASUS Secure Delete
    D510MT also features ASUS Secure Delete. It has an easy-to-use drag and drop interface that allows the user to delete all confidential data securely.
  • Solid capacitors for ultra durability
    ASUSPRO Series desktops are made with the world's best motherboards and employ premium solid capacitors. High quality components provide utmost durability, improved longevity, and enhanced thermal performance.
  • Quiet PC operation with ASUS Q-Fan technology
    ASUS Q-Fan technology monitors system loads and temperatures, and modifies the CPU fan speed accordingly. When the system is idle, the fan goes into low speed mode to lower noise levels to create a quiet working environment.
ASUS D310MT - MT - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB
Personal computer - mini tower
Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
Processor Socket
LGA1150 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM
Storage Controller
SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
Intel HD Graphics 4400
Audio Output
7.1 channel surround
GigE
OS Provided
Windows 8.1 Pro
18 cm x 39 cm x 35 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Mini tower
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
2 (Total)
Dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Storage Controller (2nd)
1 x SATA
SATA 3Gb/s
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
Card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Wake on LAN (WoL)
Slots
1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI , 2 DIMM 240-pin , 1 (total) / 0 (free) x CPU
2 x USB 2.0 , 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 (2 in front) , 1 x parallel , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
CSA, UL, C-Tick, BSMI, CB, PSB, FCC
Power supply
Operating System / Software
OS Provided
Windows 8.1 Pro
Sustainability Information
ENERGY STAR Certified
18 cm
39 cm
35 cm
8.6 kg
