Asus CROSSHAIR VI HERO ROG AMD X370 AM4 DDR4 M.2 USB3.1 ATX
Quicklinx: CR1JWS00 Mfr#: CROSSHAIR VI HERO
AMD X370 ATX Gaming motherboard with Aura Sync RGB LEDs, DDR4 3200MHz, M.2, USB 3.1 front-panel connector and type-A/C
  • Aura Sync RGB LED: Stunning synchronized effects and two Aura 4-pin RGB-strip headers
  • SupremeFX: Exclusive new codec plus intuitive Sonic Studio III and Sonic Radar III
  • Compatible with both AM3/AM4 coolers
  • ROG Water Cooling Zone : Dominate your cooling system
  • 5-Way Optimization: One-click system-wide overclocking.
  • Best gaming networking: IntelĀ® Gigabit Ethernet, LANGuard and GameFirst technologies
  • Best gaming connectivity: M.2, USB 3.1 front-panel connector and both USB 3.1 Type-A/C
  • Best gaming durability: Safeslot and premium components for maximum durability
For more than a decade, Republic of Gamers has delivered exemplary design and performance to thrill the world's best players and PC enthusiasts. Our journey is a road without end. Now, it's time for competitors to be warned and for gamers and enthusiasts to push the limits: The packed and pumped ROG Crosshair VI Hero Series motherboard is ready to defeat all challengers.
ASUS ROG CROSSHAIR VI HERO - motherboard - ATX - Socket AM4 - AMD X370
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 8 x USB 3.0 + 4 x USB 2.0 + (1 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
3-year warranty
Motherboard - ATX
Chipset Type
AMD X370
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2933 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Audio
Audio Codec
SupremeFX (S1220)
High Definition Audio
LAN
Network Controller
Intel I211-AT
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16/x8 mode (with AMD Ryzen CPU); slot not works with AMD 7th Generation A-series/Athlon CPU) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 3.0 x16 (x8 mode)
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 8 x USB 3.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x USB-C , 1 x USB 3.1 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 4 x USB 2.0
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x USB 3.1 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, BIOS FlashBack, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
Jack retasking, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, ASUS Loadline Calibration, NVIDIA 2-way SLI Technology Support, ASUS TPU (TurboV Processing Unit), Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, Onboard Button, Preboot eXecution Environment (PXE), Dual Intelligent Processors 5, LANGuard, KeyBot II, ROG SSD Secure Erase, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Sonic Radar III, Sonic Studio III, Mem TweakIt
ROG cable lables, 1 x M.2 screw, I/O back cover, ROG coasters, RGB (RGBW) LED strip extension cable, 3D printing mount package
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, Kaspersky Anti-Virus, ROG CPU-Z, ROG Mem TweakIt Utility, ASUS WebStorage, WinZip, ROG RAMDisk, Overwolf, ASUS EZ Flash 3, ROG Aura, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive, DAEMON Tools
Plug and Play
30.5 cm
24.4 cm
Limited warranty - parts and labour - 3 years
