ASUS Chromebox CN62 is a perfect choice to enhance your digital life. Easy to set up right out-of-the-box, it starts up in seconds to get you to your favorite websites and apps instantly. ASUS Chromebox CN62 is powered by a high-performance processor, and has enough power to give you ultrafast multitasking performance. It offers dual band 802.11ac Wi-Fi, along with extensive connectivity options that let you connect Chromebox CN62 to multiple displays at once.
Simple, speedy, silent
The ASUS Chromebox CN62 is a perfect choice to enhance your digital life. Easy to set up right out-of-the-box, Chromebox CN62 starts up in seconds to get you to your favorite websites and apps instantly. -
Small, sleek, and stylish
The ASUS Chromebox CN62 has a chic space-saving design, helping you to keep tidy, clutter-free environment. With its stylish chassis frame, Chromebox CN62 makes a striking addition to your home. -
Powerful processor
ASUS Chromebox CN62 is powered by a high-performance processor, and has enough power to give you ultrafast multitasking performance. It boots up instantly and lets you run apps smoothly. -
A simpler and smarter digital life
ASUS Chromebox CN62 has exceptional networking performance, with more stable connections and faster wireless speeds thanks to dual band Wi-Fi 802.11ac. Chromebox CN62 works well offline, too. Read and edit documents, spreadsheets, or presentations - even without an Internet connection! -
Dual display productivity
ASUS Chromebox CN62 lets you view content on two displays through HDMI and DisplayPort without the need for an additional graphics card. This makes multitasking a whole lot easier; you can spread out your work browsers, mirror content, or extend a single browser across multiple displays. -
Keeping you well-connected
ASUS Chromebox CN62 features a total of four USB 3.0 ports, with a conveniently-placed front-mounted fast-charge USB 3.0 port to charge your mobile devices in half the time. Chromebox CN62 also comes with Bluetooth 4.0, a 4-in-1 card reader, as well as HDMI and DisplayPort. -
Quieter than a library
ASUS Chromebox CN62 operates in remarkable silence thanks to optimized fan settings that keep noise levels down at idle. And it doesn't get much noisier at full load either. The fan helps lower operating temperatures, so you're guaranteed silent, stable performance. -
Energy efficiency
ASUS Chromebox CN62 also keeps the environment in mind, and delivers incredible energy efficiency thanks to an ultra low power design. This means you can leave Chromebox CN62 on overnight to download software updates or backup files, all without racking up electricity bills. -
Easy to get started
ASUS Chromebox CN62 takes the hassle out of home computing, allowing family members young and old to simply boot up to surf the web, view photos, or watch videos. -
Compatible with USB devices
ASUS Chromebox CN62 is compatible with a wide range of USB devices ranging from external storage drives, keyboards and mice, webcams and USB hubs.
- ASUS Chromebox 2 (CN62) G081U - USFF - Celeron 3215U 1.7 GHz - 4 GB - SSD 16 GB
- Chromebox - ultra small form factor
- Processor
- 1 x Intel Celeron 3215U / 1.7 GHz (Dual-Core)
- RAM
- 4 GB DDR3L SDRAM
- Hard Drive
- SSD 16 GB - M.2
- Optical Storage
- No optical drive
- Card Reader
- 4 in 1
- Graphics Controller
- Intel HD Graphics
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- Google Chrome OS
- Gun grey
- 12.4 cm x 12.4 cm x 4.2 cm
- 600 g
- Environmental Standards
- ENERGY STAR Qualified
- Chromebox
- Product Form Factor
- Ultra small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Gun grey
Processor / Chipset
- CPU
- Intel Celeron 3215U
- Clock Speed
- 1.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 4 GB
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Dual channel memory architecture
Hard Drive
- SSD - M.2
- Capacity
- 1 x 16 GB
Optical Storage
- No optical drive
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Wi-Fi CERTIFIED
- Slots
- 1 (total) / 0 (free) x CPU
- 4 x USB 3.0 (2 front, 2 rear) , 1 x DisplayPort , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet)
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- VESA Mounting Interface
- UL, VCCI, BSMI, CB, FCC, RCM
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Google Chrome OS
Sustainability Information
- ENERGY STAR Certified
- 12.4 cm
- 12.4 cm
- 4.2 cm
- 600 g
- Sound Emission
- 17 dB
