ASUS Chromebox 3 features a powerful processor and high capacity memory for faster, smoother and more energy-efficient performance. With full support for Android apps from Google Play, ASUS Chromebox 3 gives you the ability to run your favorite mobile apps with the power of a mini PC. It also comes equipped with a versatile USB 3.1 Gen 1 Type-C port for data transfer, power delivery and DisplayPort functionality, and supports dual 4K/UHD displays for gorgeously sharp visuals and powerful productivity.
Choose the apps that suit your needs
With a rich selection of Android apps available on Google Play, you can easily find great apps for productivity, communication, entertainment and more that let you get the most out of your ASUS Chromebox 3. -
Extensive connectivity with power-delivery technology
With support for USB Power Delivery, ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables. -
Dual display productivity + True 4K/UHD visual
ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays. When it's time to kick back and relax, ASUS Chromebox 3 lets you browse the web, view photos from your SD card on Google Photos or watch videos in 4K/UHD. ASUS Chromebox 3 even features touchscreen support for more intuitive control and engaging gameplay. -
ASUS Chromebox 3 for signage
Turn the ASUS Chromebox 3 into a plug-and-play media player for digital signage by configuring Chrome Kiosk mode. ASUS Chromebox 3 can be remotely managed, while additional maintenance is made easy thanks to the automatic update feature. The touch screen support can be configured to provide more engaging user interactions. -
ASUS Chromebox 3 for education
ASUS Chromebox 3 provides new and enriching experiences in and out of the classroom. It's simple, secure, and has an array of education apps built-in so students and teachers can work and learn right out of box. -
Powerful networking capabilities
Enjoy faster and more stable wireless connections thanks to dual band 802.11ac Wi-Fi. -
Lightweight, space saving
ASUS Chromebox 3 has a chic space-saving design. It can also be attached to the back of a display with a VESA mount, so you can create your own custom all-in-one PC for a tidy, clutter-free environment.
- ASUS Chromebox 3 N051U - mini PC - Core i5 8250U - 8 GB - SSD 64 GB
- Chromebox - mini PC
- Processor
- 1 x Intel Core i5 (8th Gen) 8250U (Quad-Core)
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 64 GB - SATA - M.2
- Optical Storage
- No optical drive
- Card Reader
- 3 in 1
- Graphics Controller
- Intel UHD Graphics 620
- Networking
- GigE, 802.11ac, Bluetooth 4.2
- OS Provided
- Google Chrome OS
- 14.85 cm x 14.85 cm x 4 cm
- 1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Chromebox
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
Hard Drive
- SSD - M.2
- Capacity
- 1 x 64 GB
- Interface Type
- SATA
Optical Storage
- No optical drive
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2
- 2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB 3.1 Gen 1
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- UL, VCCI, BSMI, CB, FCC, RCM
- Power adapter
Operating System / Software
- OS Provided
- Google Chrome OS
- ENERGY STAR Certified
- 14.85 cm
- 14.85 cm
- 4 cm
- 1 kg
- Sound Emission
- 19.3 dB
