Asus Chromebox 3 N051U Core i5-8250U 8GB 64GB SSD Chrome OS
Quicklinx: DZR9WS00 Mfr#: CHROMEBOX3-N051U
Processor Type: Core i5
Operating System: Google Chrome OS
Installed Memory: 8GB
Hard Drive Capacity: 64GB
Storage Type: SSD
  • Core i5
£468.18 ex VAT
£561.81 inc VAT
ASUS Chromebox 3 features a powerful processor and high capacity memory for faster, smoother and more energy-efficient performance. With full support for Android apps from Google Play, ASUS Chromebox 3 gives you the ability to run your favorite mobile apps with the power of a mini PC. It also comes equipped with a versatile USB 3.1 Gen 1 Type-C port for data transfer, power delivery and DisplayPort functionality, and supports dual 4K/UHD displays for gorgeously sharp visuals and powerful productivity.
  • Choose the apps that suit your needs
    With a rich selection of Android apps available on Google Play, you can easily find great apps for productivity, communication, entertainment and more that let you get the most out of your ASUS Chromebox 3.
  • Extensive connectivity with power-delivery technology
    With support for USB Power Delivery, ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables.
  • Dual display productivity + True 4K/UHD visual
    ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays. When it's time to kick back and relax, ASUS Chromebox 3 lets you browse the web, view photos from your SD card on Google Photos or watch videos in 4K/UHD. ASUS Chromebox 3 even features touchscreen support for more intuitive control and engaging gameplay.
  • ASUS Chromebox 3 for signage
    Turn the ASUS Chromebox 3 into a plug-and-play media player for digital signage by configuring Chrome Kiosk mode. ASUS Chromebox 3 can be remotely managed, while additional maintenance is made easy thanks to the automatic update feature. The touch screen support can be configured to provide more engaging user interactions.
  • ASUS Chromebox 3 for education
    ASUS Chromebox 3 provides new and enriching experiences in and out of the classroom. It's simple, secure, and has an array of education apps built-in so students and teachers can work and learn right out of box.
  • Powerful networking capabilities
    Enjoy faster and more stable wireless connections thanks to dual band 802.11ac Wi-Fi.
  • Lightweight, space saving
    ASUS Chromebox 3 has a chic space-saving design. It can also be attached to the back of a display with a VESA mount, so you can create your own custom all-in-one PC for a tidy, clutter-free environment.
ASUS Chromebox 3 N051U - mini PC - Core i5 8250U - 8 GB - 64 GB
Chromebox - mini PC
1 x Intel Core i5 (8th Gen) 8250U (Quad-Core)
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM
Hard Drive
1 x SSD 64 GB - SATA - M.2
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11ac, Bluetooth 4.2
OS Provided
Google Chrome OS
14.85 cm x 14.85 cm x 4 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
Chromebox
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
8 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Hard Drive
SSD - M.2
1 x 64 GB
Interface Type
SATA
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2
2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB 3.1 Gen 1
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, BSMI, CB, FCC, RCM
Power adapter
Operating System / Software
OS Provided
Google Chrome OS
ENERGY STAR Certified
14.85 cm
14.85 cm
4 cm
1 kg
Sound Emission
19.3 dB
Asus Chromebox 3 N051U Core i5-8250U 8GB 64GB SSD Chrome OS Bundle deal on Asus Chromebox 3 N051U Core i5-8250U 8GB 64GB SSD Chrome OS
£647.76
saving £2.42
£567.35
Storage Type: SSD
Processor Model: I5-8250U
Type: Chromebox
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 300 - 500
