Asus Chromebox 3 N031U Celeron 3865U 4GB 32GB SSD Chrome OS
Quicklinx: DZR5WS00 Mfr#: CHROMEBOX3-N031U
Processor Type: Celeron
Operating System: Google Chrome OS
Installed Memory: 4GB
Hard Drive Capacity: 32GB
Storage Type: SSD
  • Celeron
  • IEEE 802.11n
27 in stock
£206.61 ex VAT
£247.93 inc VAT
ASUS Chromebox 3 features a powerful processor and DDR4 memory for faster, smoother and more energy-efficient performance. It gives you the ability to run your favorite mobile apps with the power of a mini PC.
  • Extensive connectivity with power-delivery technology
    ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables.
  • Dual display productivity
    ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays.
  • Incredibly silent and energy efficient
    ASUS Chromebox 3 is ideal for office environments because it operates in remarkable silence, thanks to optimized fan settings that keep noise levels down. And it doesn't get much noisier at full load either. The fan helps lower operating temperatures, so you're guaranteed silent, stable performance.
  • Built-in security features
    ASUS Chromebox 3 is designed from the ground up with security in mind, so you'll be safe from viruses and malware. There's no need to buy and install additional security software, and certainly no time wasted trying to get in touch with tech support.
ASUS Chromebox 3 N031U - mini PC - Celeron 3865U - 4 GB - 32 GB
Chromebox - mini PC
1 x Intel Celeron 3865U (Dual-Core)
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Hard Drive
1 x SSD 32 GB - SATA - M.2
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel HD Graphics 610
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Google Chrome OS
Star grey
14.85 cm x 14.85 cm x 4 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Chromebox
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM) Security Chip
Star grey
Processor / Chipset
CPU
Intel Celeron 3865U
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
SO-DIMM 260-pin
Hard Drive
SSD - M.2
1 x 32 GB
Interface Type
SATA
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 2 x USB 2.0 , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 1 x USB 3.1 Gen 1
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, BSMI, CB, FCC, RCM
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Google Chrome OS
ENERGY STAR Certified
1-year warranty
14.85 cm
14.85 cm
4 cm
1 kg
Sound Emission
19.3 dB
Asus Chromebox 3 N031U Celeron 3865U 4GB 32GB SSD Chrome OS Bundle deal on Asus Chromebox 3 N031U Celeron 3865U 4GB 32GB SSD Chrome OS
£305.78
Storage Type: SSD
Processor Model: 3865U
Type: Chromebox
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 150 - 300
