Asus Chromebox 3 CN65  i7-8550U 16GB 256GB M.2 SSD Chrome OS
Quicklinx: DZR7WS00 Mfr#: CHROMEBOX3-N006U
Processor Type: Core i7
Operating System: Google Chrome OS
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i7
15 in stock
£681.00 ex VAT
£817.20 inc VAT
ASUS Chromebox 3 features a powerful processor and DDR4 memory for faster, smoother and more energy-efficient performance. It gives you the ability to run your favorite mobile apps with the power of a mini PC.
  • Extensive connectivity with power-delivery technology
    ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables.
  • Dual display productivity
    ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays.
  • Incredibly silent and energy efficient
    ASUS Chromebox 3 is ideal for office environments because it operates in remarkable silence, thanks to optimized fan settings that keep noise levels down. And it doesn't get much noisier at full load either. The fan helps lower operating temperatures, so you're guaranteed silent, stable performance.
  • Built-in security features
    ASUS Chromebox 3 is designed from the ground up with security in mind, so you'll be safe from viruses and malware. There's no need to buy and install additional security software, and certainly no time wasted trying to get in touch with tech support.
ASUS Chromebox 3 N006U - mini PC - Core i7 8550U - 16 GB - 256 GB
Chromebox - mini PC
1 x Intel Core i7 (8th Gen) 8550U (Quad-Core)
RAM
16 GB (installed) / 16 GB (max) DDR4 SDRAM
Hard Drive
1 x SSD 256 GB - M.2
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel UHD Graphics 620
GigE, 802.11ac, Bluetooth 4.2
OS Provided
Google Chrome OS
14.85 cm x 14.85 cm x 4 cm
1 kg
Environmental Standards
ENERGY STAR Qualified
Chromebox
Product Form Factor
Mini PC
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
16 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Configuration Features
2 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2
2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB 3.1 Gen 1
VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, BSMI, CB, FCC, RCM
Power adapter
Power Provided
90 Watt
Operating System / Software
OS Provided
Google Chrome OS
ENERGY STAR Certified
14.85 cm
14.85 cm
4 cm
1 kg
Sound Emission
19.3 dB
Asus Chromebox 3 CN65  i7-8550U 16GB 256GB M.2 SSD Chrome OS Bundle deal on Asus Chromebox 3 CN65 i7-8550U 16GB 256GB M.2 SSD Chrome OS
£780.17
Storage Type: SSD
Processor Model: I7-8550U
Type: Chromebox
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 500 - 750
