Asus Chromebook Rockchip RK3288 4GB 16GB 11.6" Chrome OS
LIGHTWEIGHT, LONG BATTERY LIFE AND GREAT VALUE!
Quicklinx: BK6BWS00 Mfr#: C201PA-FD0009
  • IEEE 802.11n
The line-up of sleek, sophisticated and ultra-portable laptops, ASUS Chromebooks are perfect for everyday ease-of-use. C200 features a spacious touchpad which gives easy control over multi-touch gesture inputs. With up to 11 hours of battery life - use ASUS Chromebook all day.
  • Stylish, light and always ready to go
    However you measure it, the stunningly sleek ASUS Chromebook C201PA is always ready to go - whenever you want, wherever you want. It's your perfect portable companion, featuring a breathtakingly simple design with a gorgeous finish that feels just amazing. With Chromebook C201PA, you'll always stand out from the crowd.
  • Work or play all day
    ASUS knows there's nothing more frustrating than having to find a power outlet when you've important things to do, so the power-efficient Chromebook C201 is designed to last for up to an incredible 13 hours on a single charge. Whatever you're doing, you can be sure that C201 will keep going through the working day - and beyond!
  • See and be seen more clearly
    ASUS has engineered the 11.6-inch LED-backlit display on ASUS Chromebook C201PA so that it has the narrowest bezel in its class for stunningly vivid, distraction-free visuals. And the HD front camera means you can enjoy crisp, clear and natural-looking video calls you're your friends, colleagues or family.
  • Typing comfort, redefined
    Typing is now more comfortable than ever with the full-size one-piece chiclet keyboard. An improved back assembly provides 1.5 mm of key travel and minimal key float, so you get a more solid typing feel. The spacious touchpad found on C201 has a palm rejection feature which differentiates between actual fingertip and palm contact to counter unintentional cursor movement.
  • Powerfully clear sound
    It may be slim and light, but that doesn't mean C201 has to compromise on sound quality. With its high-quality stereo speakers and extra-large resonant chambers that generate up to 85 dB of high-fidelity audio, Chromebook C201PA can deliver surround sound that's as good as much larger laptops, with crisp and powerful audio to give you an immersive experience for both music and video streaming.
  • Get connected fast
    Connectivity is everything in the modern world, so Chromebook C201 features the latest, fastest 802.11ac Wi-Fi for speeds up to three times faster than 802.11n. C201 also features power-efficient Bluetooth 4.0 for fast connectivity with great battery life.
ASUS Chromebook C201PA-FD0009 - 11.6" - Rockchip RK3288C - 4 GB RAM - 16 GB eMMC
Chromebook
Operating System
Chrome OS
Rockchip RK3288C / 1.8 GHz
4 GB LPDDR3 (provided memory is soldered)
Storage
16 GB eMMC
Display
11.6" LED backlight 1366 x 768 / HD
Graphics
ARM Mali-T764
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell - up to 13 hours
Security
Trusted Platform Module (TPM) Security Chip
Navy blue, silver IMR
28.7 cm x 19.4 cm x 1.79 cm
900 g
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Number of Cores
Quad-Core
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
16 GB eMMC
Display
11.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
Glare
Audio & Video
Graphics Processor
ARM Mali-T764
Camera
Yes - HD
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Multi-gesture touch pad
Communications
Wireless
2-cell lithium polymer
38 Wh
Run Time
Up to 13 hours
AC Adapter
Input
Output
24 Watt, 12 V, 2 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 2.0 , Micro-HDMI
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 2 years)
Case Material
Plastic
Security
Power adapter
900 g
