The line-up of sleek, sophisticated and ultra-portable laptops, ASUS Chromebooks are perfect for everyday ease-of-use. C200 features a spacious touchpad which gives easy control over multi-touch gesture inputs. With up to 11 hours of battery life - use ASUS Chromebook all day.
Stylish, light and always ready to go
However you measure it, the stunningly sleek ASUS Chromebook C201PA is always ready to go - whenever you want, wherever you want. It's your perfect portable companion, featuring a breathtakingly simple design with a gorgeous finish that feels just amazing. With Chromebook C201PA, you'll always stand out from the crowd. -
Work or play all day
ASUS knows there's nothing more frustrating than having to find a power outlet when you've important things to do, so the power-efficient Chromebook C201 is designed to last for up to an incredible 13 hours on a single charge. Whatever you're doing, you can be sure that C201 will keep going through the working day - and beyond! -
See and be seen more clearly
ASUS has engineered the 11.6-inch LED-backlit display on ASUS Chromebook C201PA so that it has the narrowest bezel in its class for stunningly vivid, distraction-free visuals. And the HD front camera means you can enjoy crisp, clear and natural-looking video calls you're your friends, colleagues or family. -
Typing comfort, redefined
Typing is now more comfortable than ever with the full-size one-piece chiclet keyboard. An improved back assembly provides 1.5 mm of key travel and minimal key float, so you get a more solid typing feel. The spacious touchpad found on C201 has a palm rejection feature which differentiates between actual fingertip and palm contact to counter unintentional cursor movement. -
Powerfully clear sound
It may be slim and light, but that doesn't mean C201 has to compromise on sound quality. With its high-quality stereo speakers and extra-large resonant chambers that generate up to 85 dB of high-fidelity audio, Chromebook C201PA can deliver surround sound that's as good as much larger laptops, with crisp and powerful audio to give you an immersive experience for both music and video streaming. -
Get connected fast
Connectivity is everything in the modern world, so Chromebook C201 features the latest, fastest 802.11ac Wi-Fi for speeds up to three times faster than 802.11n. C201 also features power-efficient Bluetooth 4.0 for fast connectivity with great battery life.
- ASUS Chromebook C201PA-FD0009 - 11.6" - Rockchip RK3288C - 4 GB RAM - 16 GB eMMC
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Rockchip RK3288C / 1.8 GHz
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- ARM Mali-T764
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell - up to 13 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Navy blue, silver IMR
- 28.7 cm x 19.4 cm x 1.79 cm
- 900 g
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Number of Cores
- Quad-Core
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- Glare
Audio & Video
- Graphics Processor
- ARM Mali-T764
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Multi-gesture touch pad
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 38 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 24 Watt, 12 V, 2 A
Connections & Expansion
- Headphone/microphone combo jack , 2 x USB 2.0 , Micro-HDMI
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 2 years)
- Case Material
- Plastic
- Security
- Included Accessories
- Power adapter
- 900 g
