Packed with useful, practical and innovative features, the Asus Chrome book Flip has everything you need whether you're working, entertaining yourself or keeping in touch with friends and family.
As the name suggests, the Asus Flip comes equipped with a unique screen that can be rotated a full 360 degrees - so you can switch straight from using it as a Chromebook to using it a tablet. Its generous battery life of up to nine hours gives you plenty of time to get those essential everyday tasks done, even when you're on the move.
The Chromebook Flip's responsive and spacious touchpad enhances your freedom and control, while its multi-touch screen is equipped with exclusive Asus touch-sensor technology - allowing for a much more accurate and responsive user experience compared to conventional touchscreens.
What's more, this Chromebook Asus also supports dual-band 802.11ac Wi-Fi, giving you a reliably strong signal whether you're streaming videos and music or keeping in touch with your mates on social media. There's even BlueTooth 4.1 connectivity.
For performance, versatility and exceptional value for money, look no further than the Chromebook Flip.
Instant response to the lightest touch
C100 is designed to respond instantly to your every touch. ASUS has doubled the touch sensitivity, so even the slightest movement of your fingertips is detected, and it only needs the lightest of touches to work perfectly. In fact, it's so good that it reacts accurately even to a child's small fingertips! -
ASUS TruVivid brings color to life with brilliant clarity
C100 adopts ASUS TruVivid technology to improve screen clarity, brightness, and touch responsiveness. This technology transforms the conventional four-layer display design - composed of Corning Corolla cover glass, touch panel, air gap, and LCD module - into a two-layer, full lamination design, eliminating the air gap and combining the cover glass and touch panel layers. This offers higher optical transparency (>94%) than conventional display, resulting in brilliant color clarity and brightness. -
A clear view, from any angle
178-degree wide viewing angles ensure that images never look washed out or lacking in contrast, even when viewing them from off-center. This makes C100 perfect for sharing screen contents with a group of people, whatever mode C100 is in. -
Work or play - all day
ASUS knows there's nothing more frustrating than having to find a power outlet when you've important (or fun!) things to do, so the power-efficient Chromebook Flip C100 is designed to last for up to an incredible nine hours on a single charge. Whatever you're doing, you can be sure that Flip C100 will keep going through the working day - and beyond! -
Get connected - fast
Connectivity is everything in the modern world, so Chromebook Flip C100 features the latest, fastest 802.11ac Wi-Fi for speeds up to three times (3X) faster than 802.11n. The 3D antenna in the lid is specially designed to give superb reception through the aluminum casing, so you'll always get a strong, reliable signal. Flip C100 also features power-efficient Bluetooth 4.0 for fast connectivity with great battery life. -
Your flexible companion
Despite its slim design, Chromebook Flip C100 has a complete range of I/O ports to give you complete flexibility. Whether you want to connect to a big-screen TV via the HDMI port, use a USB drive for transferring data, or share your photos on the cloud after uploading them from the micro SD Card slot, Flip C100 has everything you need! -
Powerfully clear sound
It may be slim and light, but that doesn't mean Chromebook Flip C100 has to compromise on sound quality. With its twin high-quality stereo speakers generating up to 80dB of high-fidelity audio, it can deliver surround sound that's both crisp and powerful to give you an immersive experience for both music and video streaming. -
Simple, secure and reliable
With its automatic updates and built-in anti-virus protection, Chrome OS frees you from the worry of keeping your Chromebook Flip C100 safe, secure and always up to date. And as it's built on the rock-solid security of your personal Google account, all your private documents, emails, photos and personal data are kept safe at all times. With integrated instant access to all the amazing apps in the Chrome Web Store, Chromebook Flip C100 opens up a wonderful new world for you.
- ASUS Chromebook Flip C100PA-FS0002 - 10.1" - Rockchip RK3288C - 4 GB RAM - 16 GB eMMC
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Rockchip RK3288C
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- ARM Mali-T764
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac
- Battery
- 2-cell - up to 9 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Metallic silver
- 26.3 cm x 18.2 cm x 1.56 cm
- 900 g
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Rockchip RK3288C
- Number of Cores
- Quad-Core
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 16 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 50% NTSC
- Glare, WideView
Audio & Video
- Graphics Processor
- ARM Mali-T764
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
Communications
- Wireless
- 802.11a/b/g/n/ac
- Technology
- 2-cell lithium polymer
- Capacity
- 31 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 24 Watt, 12 V, 2 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , 2 x USB 2.0 , Micro-HDMI
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 2 years)
- Metallic silver
- Security
- Included Accessories
- Power adapter
- 900 g
Sustainability Information
- TCO Certified
