Asus Chromebook Flip Rockchip RK3288 4GB 16GB 10.1" Chrome OS
LIGHTWEIGHT, LONG BATTERY LIFE AND GREAT VALUE!
Quicklinx: BK69WS00 Mfr#: C100PA-FS0002
  • IEEE 802.11n
Packed with useful, practical and innovative features, the Asus Chrome book Flip has everything you need whether you're working, entertaining yourself or keeping in touch with friends and family.
As the name suggests, the Asus Flip comes equipped with a unique screen that can be rotated a full 360 degrees - so you can switch straight from using it as a Chromebook to using it a tablet. Its generous battery life of up to nine hours gives you plenty of time to get those essential everyday tasks done, even when you're on the move.
The Chromebook Flip's responsive and spacious touchpad enhances your freedom and control, while its multi-touch screen is equipped with exclusive Asus touch-sensor technology - allowing for a much more accurate and responsive user experience compared to conventional touchscreens.
What's more, this Chromebook Asus also supports dual-band 802.11ac Wi-Fi, giving you a reliably strong signal whether you're streaming videos and music or keeping in touch with your mates on social media. There's even BlueTooth 4.1 connectivity.
For performance, versatility and exceptional value for money, look no further than the Chromebook Flip.
  • Instant response to the lightest touch
    C100 is designed to respond instantly to your every touch. ASUS has doubled the touch sensitivity, so even the slightest movement of your fingertips is detected, and it only needs the lightest of touches to work perfectly. In fact, it's so good that it reacts accurately even to a child's small fingertips!
  • ASUS TruVivid brings color to life with brilliant clarity
    C100 adopts ASUS TruVivid technology to improve screen clarity, brightness, and touch responsiveness. This technology transforms the conventional four-layer display design - composed of Corning Corolla cover glass, touch panel, air gap, and LCD module - into a two-layer, full lamination design, eliminating the air gap and combining the cover glass and touch panel layers. This offers higher optical transparency (>94%) than conventional display, resulting in brilliant color clarity and brightness.
  • A clear view, from any angle
    178-degree wide viewing angles ensure that images never look washed out or lacking in contrast, even when viewing them from off-center. This makes C100 perfect for sharing screen contents with a group of people, whatever mode C100 is in.
  • Work or play - all day
    ASUS knows there's nothing more frustrating than having to find a power outlet when you've important (or fun!) things to do, so the power-efficient Chromebook Flip C100 is designed to last for up to an incredible nine hours on a single charge. Whatever you're doing, you can be sure that Flip C100 will keep going through the working day - and beyond!
  • Get connected - fast
    Connectivity is everything in the modern world, so Chromebook Flip C100 features the latest, fastest 802.11ac Wi-Fi for speeds up to three times (3X) faster than 802.11n. The 3D antenna in the lid is specially designed to give superb reception through the aluminum casing, so you'll always get a strong, reliable signal. Flip C100 also features power-efficient Bluetooth 4.0 for fast connectivity with great battery life.
  • Your flexible companion
    Despite its slim design, Chromebook Flip C100 has a complete range of I/O ports to give you complete flexibility. Whether you want to connect to a big-screen TV via the HDMI port, use a USB drive for transferring data, or share your photos on the cloud after uploading them from the micro SD Card slot, Flip C100 has everything you need!
  • Powerfully clear sound
    It may be slim and light, but that doesn't mean Chromebook Flip C100 has to compromise on sound quality. With its twin high-quality stereo speakers generating up to 80dB of high-fidelity audio, it can deliver surround sound that's both crisp and powerful to give you an immersive experience for both music and video streaming.
  • Simple, secure and reliable
    With its automatic updates and built-in anti-virus protection, Chrome OS frees you from the worry of keeping your Chromebook Flip C100 safe, secure and always up to date. And as it's built on the rock-solid security of your personal Google account, all your private documents, emails, photos and personal data are kept safe at all times. With integrated instant access to all the amazing apps in the Chrome Web Store, Chromebook Flip C100 opens up a wonderful new world for you.
ASUS Chromebook Flip C100PA-FS0002 - 10.1" - Rockchip RK3288C - 4 GB RAM - 16 GB eMMC
Chromebook - flip design
Operating System
Chrome OS
Rockchip RK3288C
4 GB LPDDR3 (provided memory is soldered)
Storage
16 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
ARM Mali-T764
Integrated Webcam
802.11a/b/g/n/ac
2-cell - up to 9 hours
Security
Trusted Platform Module (TPM) Security Chip
Metallic silver
26.3 cm x 18.2 cm x 1.56 cm
900 g
Operating System
Google Chrome OS
Processor / Chipset
CPU
Rockchip RK3288C
Number of Cores
Quad-Core
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
16 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
250 cd/m²
Colour Gamut
50% NTSC
Glare, WideView
Audio & Video
Graphics Processor
ARM Mali-T764
Camera
Yes - HD
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Communications
Wireless
802.11a/b/g/n/ac
2-cell lithium polymer
31 Wh
Run Time
Up to 9 hours
AC Adapter
Input
Output
24 Watt, 12 V, 2 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , 2 x USB 2.0 , Micro-HDMI
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 2 years)
Metallic silver
Security
Power adapter
900 g
Sustainability Information
TCO Certified
