Asus Chromebook C434TA Intel Core i5-8200Y 8GB 128GB 14" ChromeOS
Quicklinx: F7JMWS00 Mfr#: C434TA-AI0041
Display Size: 14in
Processor Model: I5-8200Y
Operating System: Google Chrome OS
Installed Memory: 8GB
Hard Drive Capacity: 128GB
  • Core i5
  • Bluetooth 4.0
More than 50 in stock
£679.96 ex VAT
£815.95 inc VAT
The stunning ASUS Chromebook Flip C434 takes convertible Chromebook design to another level. Its stylish contemporary looks, compact portability and powerful specifications are all designed to let you get things done with no fuss, all day and every day.
  • Crafted to perfection
    ASUS Chromebook Flip C434 is styled for today, with a precision-crafted all-aluminum chassis finished with elegant diamond-cut anodized edges. Its refined looks are the perfect match for those who appreciate on-the-go versatility combined with peerless design.
  • Unbounded vision with the NanoEdge display
    Designed to give you the most screen area in the least physical space, the four-sided NanoEdge display is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes. The ultra-slim bezels are thin at the sides for a near-borderless experience, and the crisp, clear, high-resolution screen gives you a beautiful creative workplace.
  • Precision-engineered versatility
    Featuring a precision-engineered mechanism, the versatile 360° ErgoLift hinge on ASUS Chromebook Flip C434 has a silky-smooth action that holds the display securely at any angle. This innovative hinge has a dual action that lifts and tilts the keyboard into the perfect typing position when the display is rotated into laptop mode. It also helps enhance the powerful audio, by creating extra space underneath the laptop.
  • Breeze through your tasks all day long
    Featuring a powerful processor, ASUS Chromebook Flip C434 delivers great performance for popular apps, with extraordinary battery life. It is designed to last for hours on a single charge, so you can work or play throughout the day while you're on the move.
  • No-compromise productivity
    The ultra-portable laptop deserves an exceptional keyboard. ASUS Chromebook Flip C434 has a full-size backlit keyboard with an impressive key travel, making typing more comfortable and more accurate. Its large touchpad is cleverly engineered for maximum comfort, accuracy and smooth control, incorporating palm-rejection technology and multitouch gesture support.
  • Powerfully clear sound
    Despite its thin and light design, ASUS Chromebook Flip C434 doesn't compromise on sound quality. With dual high-quality stereo speakers and extra-large resonant chambers that generate high-fidelity audio, it can deliver surround-sound effects that are good as much larger laptops, with crisp and powerful sound to give you an immersive experience for both music and video streaming.
ASUS Chromebook Flip C434TA AI0041 - 14" - Core i5 8200Y - 8 GB RAM - 128 GB eMMC
Chromebook - flip design
Operating System
Chrome OS
Intel Core i5 (8th Gen) 8200Y / 1.3 GHz (3.9 GHz) / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
128 GB - eMMC
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 615
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11ac
3-cell - up to 10 hours
Spangle silver
32.1 cm x 20.2 cm x 1.57 cm
1.45 kg
SAR
0.715 W/kg (body), 0.715 W/kg (limb)
Limited warranty - pick-up and return - 1 year
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Dual-Core
Cache
4 MB
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1867 MHz
Rated Speed
1867 MHz
Storage
Main Storage
128 GB SSD - (eMMC)
Display
14"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Bezel Type
Flat front
100% sRGB colour gamut, NanoEdge display, 178° viewing angle
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
3-cell
48 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt, 15 V
Connections & Expansion
2 x USB-C 3.1 Gen 1 , Headphone/microphone combo jack , USB 3.1 Gen 1
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Spangle silver
ErgoLift
USB-C power adapter
SAR Value
1.45 kg
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 615
Hard Drive Type: SSD
Brand: Asus
Price Range Ex VAT: 500 - 750
