Asus Cerberus Gaming Keyboard
Quicklinx: BRQTWS00 Mfr#: 90YH00R1-B2EA00
Forged from a full SECC metal plate, Cerberus Gaming Keyboard has a rugged, durable design that stands up to the rigors of continuous, intense gaming.
Cerberus Gaming Keyboard features a splash-proof design to protect against accidentally spilled liquids. An integrated drain hole prevents liquids from being trapped inside the keyboard and ensures easy cleanup after spills, so you can get back to gaming with minimal disruption.
Cerberus Gaming Keyboard is equipped with 12 dedicated and easy-to-reach macro keys, so you can issue custom in-game commands with a single keystroke and enjoy complete tactical flexibility.
  • Full SECC metal plate
  • Splash-proof design with drain hole
  • 12 macro keys
  • Fully rubberized feet
    With fully rubberized feet that provide enhanced friction on any surface, Cerberus Gaming Keyboard stays firmly in place during even the most intense gaming sessions, so you can push for the win without pushing your keyboard around.
ASUS CERBERUS - keyboard - black
Keyboard
Backlit
USB
Wired
Hot Keys Function
Volume, play/pause, previous track, next track, Windows key lock
47.1 cm x 18.6 cm x 4.1 cm
1.1 kg
Keyboard
Backlit
USB
Input Device
Hot Keys Function
Keyboard Technology
Membrane
Simultaneous Key Press Quantity
19
47.1 cm
18.6 cm
4.1 cm
1.1 kg
Cable Length
2 m
Microsoft Windows XP, Microsoft Windows 7, Windows 8 / 8.1, Windows 10
