Product
Asus Cerberus Entry Level Headset
Quicklinx: BRQ8WS00 Mfr#: 90YH0061-B1UA00
Recommended Use: Computer, Game console
Connectivity: Wired
Earcover : Binaural
£42.17 ex VAT
£50.60 inc VAT
Winning gamers need winning accessories and Cerberus is designed to help you secure victory in every scenario - and it's also a great headset for everyday listening! Connect Cerberus to your desktop, laptop or smart device to experience superb sound with brilliant detail and punchy bass no matter what you do or where you do it.
If you've not felt the power of 60 mm neodymium-magnet drivers then listen with Cerberus - you'll experience unrivaled punch and audio immersion that's utterly convincing. When gaming you'll hear every gunshot and know enemies are nearby from their footsteps alone. Then, switch to audio for roomy stadium rock, crisp and clear spoken-word listening or movie soundtracks that sound so real.
Cerberus has full-size 100 mm polyurethane-coated leather ear cushions for great durability and effective noise isolation, so you can enjoy audio without being disturbed by the outside world. And Cerberus is designed with comfort that lasts: the highly-breathable cushions and the headband's finely-balanced clamping forces mean you can listen for much longer.
  • Superb, distraction-free sound in every scenario
  • Large 60 mm neodymium-magnet drivers
  • Works with both PCs and Mac computers
    You can forget compatibility worries with Cerberus because it works with almost any device. The 1.2 m connecting cable is accompanied by a 1.3 m extension with a Y-split that provides separate headphone and mic plugs along, for great compatibility and an overall cable length of 2.5 m. The detachable boom mic is perfect for in-game communication - so you can chat and always be heard!
  • Works with smartphones and tablets
    Cerberus is also perfect for smart devices, thanks to the in-line mic - it's so convenient for on-the-go chat. Just pop the four-pole 3.5 mm jack plug into your smart device to keep in touch with family or friends on the road. ASUS engineers' research shows that 1.2 m cable is a perfect length for mobile use - so no more knots and tangles!
  • Revel in undisturbed gaming and music enjoyment
ASUS CERBERUS - headset
Headset - wired
Recommended Use
Game console, computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Detachable - boom
Sony PlayStation 4
Headset
18.253 cm
15.16 cm
10.133 cm
266 g
Recommended Use
Headphones
Circumaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
60 mm
Magnet Material
Neodymium magnet
In-Cord Volume Control
Microphone
Boom
Frequency Response
50 - 16000 Hz
Connector Type
Audio line-in / headphones (mini-phone stereo 3.5 mm 4-pole)
Headset cable - 1.2 m , Audio splitter - 1.3 m
Sony PlayStation 4
Recommended Use: Game console
Connectivity: Wired
Earcover : Binaural
Brand: Asus
Price Range Ex VAT: 0 - 50
