Asus C213NA Celeron N3350 4GB 32GB eMMC 11.6" Stylus Pen ChromeOS
Quicklinx: D2P8WS00 Mfr#: C213NA-BW0034-OSS
  • Celeron
  • IEEE 802.11n
The ASUS Chromebook C213 is the ideal education computer for every school IT manager, student, and teacher. With its classroom ruggedness, the ASUS Chromebook C213 is developed to meet the daily rigors and intense usage by students both inside and outside of the classroom. Beyond its rugged construction, the ASUS Chromebook C213 is also designed for easy maintenance to minimize downtime. The result is a Chromebook, which is designed for maximum usage, creating more learning opportunities for students.
  • Robust, reinforced rubber, wrapped protective guard
    All exterior edges and corners of the C213 Chromebook are protected, using reinforced nano-molding technology, which ensures critical components are secured.
  • Spill-proof keyboard a must for the classroom
    A classroom of students presents many possible scenarios for accidents. Very common is the accidental spilling of liquid on the notebook and keyboard. That's why the C213 Chromebook keyboard is spill-proof and can repel liquid, giving you the additional peace of mind.
  • Easy-grip design for better holding traction
    Imagine a typical school day and it will be easy to understand the potential hazards in the accidental dropping of the notebook. From the loose of grip, when carrying the notebook, from passing the notebook from one student to another or even an accidental push off from the table are very real scenarios. That's why the C213 Chromebook is designed with 2 special grips, which are strategically located to minimize these hazards.
  • 180-degree hinge allows a fully open Chromebook
    Ideal for easy viewing, especially for group study or collaboration.
  • Larger character-printed keys
    Provides superior legibility for easier typing.
  • Anti-glare display
    Easy to view even in sunlight and less strenuous on the eyes.
  • Long hours of battery life
    A notebook's battery life, which can last the full school day and without having to sacrifice on the brightness of the display, are crucial for students. Not forgetting the field trips or projects outside of the classroom environment, where there is no available power source, makes the battery life even more critical. There is no worries with the C213 Chromebook, as it has a long battery life with normal brightness to last the full school day.
ASUS Chromebook Flip C213NA BW0034 - 11.6" - Intel Celeron - N3350 - 4 GB RAM - 32 GB eMMC
Chromebook - flip design
Operating System
Chrome OS
Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
4 GB LPDDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Input Device
Stylus
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell
Grey, dark grey
30.7 cm x 19.9 cm x 2.06 cm
1.3 kg
Limited warranty - 3 years - on-site
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR4 SDRAM
Storage
Main Storage
32 GB eMMC
Display
11.6"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
50% NTSC
Glare, WideView
Audio & Video
Graphics Processor
Camera
Resolution
5 Megapixel (rear), 1 Megapixel (front)
Image Sensor Type
CMOS
Video Resolutions
720p
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad, stylus
Communications
Wireless
4-cell Lithium Ion
46 Wh
AC Adapter
Input
Output
45 Watt, 20 V, 2.25 A
Connections & Expansion
Interfaces Details
2 x USB 3.0 , 2 x USB-C 3.1 Gen 1 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Grey, dark grey
ASUS USB Charger+
Stylus, power adapter
1.3 kg
Sustainability Information
TCO Certified
