ASUS Chromebook C202
CLASSROOM-RUGGED DESIGN:
LESS DOWNTIME. MORE LEARNING TIME.
The ASUS Chromebook C202 is the ideal education computer for every school IT manager, student, and teacher. With its classroom ruggedness, the ASUS Chromebook C202 is developed to meet the daily rigors and intense usage by students both inside and outside of the classroom. Beyond its rugged construction, the ASUS Chromebook C202 is also designed for easy maintenance to minimize downtime. The result is a Chromebook which is designed for maximum usage, creating more learning opportunities for students.
- Robust and reinforced rubber wrapped protective guard reduces the impact from any accidents.
- Surpassed durability testing ensuring lasting durability and better reliability.
- Easy grip design 2 strategically placed grips provide better holding traction and reduce any slipping incident.
Robust, reinforced rubber wrapped protective guard
Reduces the impact from any accidents.
All 4 exterior edges and corners of the C202 Chromebook are protected using reinforced nano-molding technology which ensure critical components are secured.
Ensuring lasting durability and better reliability
More stringent Drop Test1 from a drop height of 3.9ft ensures function without disruption. Extreme twist force and high-pressure testing ensure that it can withstand the physical stress when used frequently over long periods of time. Various shock trials, as well as multiple frequency vibration testing, ensure the solid and sturdy construction of the device.
Spill proof keyboard a must for the classroom
A classroom of students presents many possible scenarios for accidents. One of the most common is the accidental spilling of liquid on the notebook and keyboard. That's why the C202 Chromebook keyboard is spill proof2 and can repel up to 66cc of liquid giving you the additional peace of mind.
Easy grip design for better holding traction
Imagine a typical school day and it will be easy to understand the potential hazards in the accidental dropping of the notebook. From the lose of grip when carrying the notebook, from passing the notebook from one student to another or even an accidental push off from the table are very real scenarios. That's why the C202 Chromebook is designed with 2 special grips which are strategically located to minimize these hazards.
180-degree hinge allows a fully open Chromebook
Ideal for easy viewing, especially for group study or collaboration.
15% larger character-printed keys
Provides superior legibility for easier typing.
Up to 10 hours of battery life
A notebook's battery life which can last the full school day and without having to sacrifice on the brightness of the display are crucial for students. Not forgetting the field trips or projects outside of the classroom environment where there is no available power source makes the battery life even more critical. There is no worries with the C202 Chromebook as it has a battery life of up to 10 hours3 with normal brightness to last the full school day.
Â
Robust, reinforced rubber, wrapped protective guard
All 4 exterior edges and corners of the C202 Chromebook are protected, using reinforced nano-molding technology, which ensure critical components are secured. -
Spill-proof keyboard a must for the classroom
A classroom of students presents many possible scenarios for accidents. Very common is the accidental spilling of liquid on the notebook and keyboard. That's why the C202 Chromebook keyboard is spill-proof and can repel liquid, giving you the additional peace of mind. -
Easy-grip design for better holding traction
Imagine a typical school day and it will be easy to understand the potential hazards in the accidental dropping of the notebook. From the loose of grip, when carrying the notebook, from passing the notebook from one student to another or even an accidental push off from the table are very real scenarios. That's why the C202 Chromebook is designed with 2 special grips, which are strategically located to minimize these hazards. -
Ideal for easy viewing, especially for group study or collaboration. -
Larger character-printed keys
Provides superior legibility for easier typing. -
Anti-glare display
Easy to view even in sunlight and less strenuous on the eyes. -
Long hours of battery life
A notebook's battery life, which can last the full school day and without having to sacrifice on the brightness of the display, are crucial for students. Not forgetting the field trips or projects outside of the classroom environment, where there is no available power source, makes the battery life even more critical. There is no worries with the C202 Chromebook, as it has a long battery life with normal brightness to last the full school day.
- Processor
- Intel® Celeron® Dual-Core N3060 Processor, 1.6 GHz (2 M Cache, up to 2.48 GHz)
- Operating System
- Chrome OS
- Chipset
- Integrated Intel® CPU
- Memory
- LPDDR3 MHz SDRAM
- OnBoard Memory
- 2 GB
- Display
- 11.6" 16:9 HD (1366x768) anti-glare
- Graphic
- Integrated Intel® HD Graphics
- Storage
- 16GB eMMC
- Card Reader
- card reader ( SD )
- Camera
- HD Web Camera
- Networking
- Integrated 802.11 ac, Built-in Bluetoothâ„¢ V4.0
- Interface
- 1 x COMBO audio jack, 2 x USB 3.0 port(s), 1 x HDMI, 1 x SD card reader, 1X AC adapter plug
- Audio
- Built-in Stereo 2 W Speakers And Microphone
- Battery
- 2Cells Polymer Battery
- Power Adaptor
- Plug Type :ø4 (mm)
- Output :
- 19 V DC, 2.1 A, 40 W
- Input :
- 100 -240 V AC, 50/60 Hz universal
- Dimensions
- 294 x 200 x 22.5 mm (WxDxH) (w/ 2cell battery)
- 1.2 kg with Battery
- Security
- TPM (Trusted Platform Module)
