Asus Blu-Ray Rewriter Black OEM Drive (SATA/BD-R: 16x/DVD±R: 16x)
Quicklinx: 9K1NWS00 Mfr#: BW-16D1HT/BLK/B/AS
Drive Type: BDXL Writer
Enclosure Type: Internal
Interface: Serial ATA
Colour: Black
Type: Disk drive
19 in stock
£68.85 ex VAT
£82.62 inc VAT
ASUS BW-16D1HT is a powerful and energy-saving Blu-ray writer which is capable of writing from 16x BD format. Its M-Disc compatibility allows consumers store their priceless photos or documents for long time. It is suitable for anyone who desires a total storage and data backup solution.
ASUS BW-16D1HT - BDXL drive - Serial ATA - internal
BDXL drive - internal
Serial ATA
14.6 cm x 17 cm x 4.1 cm
750 g
Optical Storage
BDXL - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD) / 12x (BD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 16x (BD-R) / 12x (BD-R DL) / 6x (BD-R TL) / 6x (BD-R QL) / 6x (BD-R LTH)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL) / 2x (BD-RE TL)
Media Load Type
Tray
Serial ATA
14.6 cm
17 cm
4.1 cm
750 g
Optical Storage
BDXL - 5.25" x 1/2H
Read Speed
Write Speed
Supported Media Formats
CD-ROM
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL, BD-R QL, BD-R TL, BD-RE TL, BD-R LTH, DVD-ROM DL
Media Load Type
Tray
Access Time
160 ms (DVD), 150 ms (CD), 180 ms (BD), 180 ms (BD DL)
Horizontal/vertical mountable, E-Green Engine technology, Disc Encryption, M-DISC support, Drag and Burn
1 x SATA 3Gb/s - 7 pin Serial ATA
Compatible Bay
5.25" x 1/2H - front accessible
Package Type
Bulk
Software Included
CyberLink Power2Go 8
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
System Requirements Details
Pentium D - 3.4 GHz - RAM: 1 GB - HDD: 10 GB
5 °C
20 - 80% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9K1N 041926
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £41.99
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Colour: Black
Type: Disk drive
Brand: Asus
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
