Product
Asus BE24AQLB-G 24.1" 1920x1200 5ms DVI-D VGA Monitor
Quicklinx: CW2KWS00 Mfr#: BE24AQLB-G
Diagonal Size: 24.1in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£234.96 ex VAT
£281.95 inc VAT
BE24AQLB-G LCD monitor features a WUXGA 1920x1200 resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
  • Vivid, lifelike visuals with 178° wide-view angles
  • Extensive connectivity
    BE24AQLB-G LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports.
  • Bundled with the MiniPC kit
    ASUS BE24AQLB-G monitor is bundled with the MiniPC kit for those who need to mount mini PCs on the monitor, to make the desktop clutter-free and space saving.
  • Ultra-low Blue Light monitor
    The TÜV Rheinland-certified ASUS Blue Light Filter protects you from harmful blue light, and you can easily access its four different filter settings via a hotkey. ASUS BE24AQLB-G has undergone stringent performance tests and has been certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
  • Flicker-free technology
    It's time to say goodbye to those tired, strained eyes. ASUS BE24AQLB-G features TÜV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
ASUS BE24AQLB-G - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Grey
56.1 cm x 21.1 cm x 38.1 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, PSE Mark, ErP Ready, UkrSEPRO, TCO Displays 6.0, RCM, ISO9241-307, TUV Rheinland Low Blue Light Certification
3 years warranty
Display Type
Diagonal Size
24.1"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology
Grey
56.1 cm x 21.1 cm x 38.1 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Audio line-in , Headphones , DisplayPort , VGA , DVI-D , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
MiniPC kit
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
25.4 Watt
Power Consumption (Off Mode)
0 Watt
Dimensions & Weight Details
Without stand - width: 56.1 cm - depth: 5 cm - height: 37.2 cm , With stand - width: 56.1 cm - depth: 21.1 cm - height: 38.1 cm - weight: 6.2 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus BE24AQLB-G 24.1 Bundle deal on Asus BE24AQLB-G 24.1" 1920x1200 5ms DVI-D VGA Monitor
£329.97
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
