Asus BE229QLB 21.5" 1920 x 1080 5ms VGA DVI Monitor
VIVID, LIFELIKE VISUALS WITH 178° WIDE-VIEW ANGLES
Quicklinx: CW2RWS00 Mfr#: BE229QLB
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£133.81 ex VAT
£160.57 inc VAT
BE229QLB LCD monitor features a Full HD(1920x1080) resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
BE229QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports.
Say goodbye to tired, strained eyes. ASUS BE229QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display.
ASUS Flicker-Free technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid Computer Vision Syndrome.
  • Vivid, lifelike visuals with 178° wide-view angles
  • Extensive connectivity
  • Great viewing comfort with Eye Care technology and ergonomic design for everyday computing
  • ASUS Flicker Free technology
  • ASUS Low Blue Light technology - Blue Light Filter
    The ASUS Low Blue Light monitors allow users to access four different Blue Light Filter settings onscreen, which you can choose from level 1 to level 4, depending on different tasks, to effectively reduce harmful blue light from the screen for the best viewing comfort.
  • Versatile comfort with ergonomic stand design
    With an ergonomically-designed stand with tilt, swivel, pivot, and height adjustments, the BE229QLB provides a comfortable viewing and usage experience. The ability to pivot the screen clockwise or counterclockwise 90 degrees for use in portrait mode comes in handy when working with long documents, coding or website browsing. Furthermore, the BE229QLB features a quick release stand to provide an easier way for frequent VESA wall mount scenario setup. Screw-free and it's done in seconds.
  • Bundled with the MiniPC kit
    ASUS BE229QLB monitor is bundled with the MiniPC kit for those who need to mount mini PCs on the monitor, to make the desktop clutter-free and space saving .
ASUS BE229QLB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
51.4 cm x 21.1 cm x 34.7 cm
5.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
UL, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, MEPS, ErP Ready, UkrSEPRO, RCM, ISO9241-307, TUV Rheinland Low Blue Light Certification
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology
51.4 cm x 21.1 cm x 34.7 cm - with stand
5.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Audio line-in , Headphones , DisplayPort , VGA , DVI-D , 2 x USB 2.0
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
MiniPC kit
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
Dimensions & Weight Details
Without stand - width: 51.4 cm - depth: 5 cm - height: 31.2 cm , With stand - width: 51.4 cm - depth: 21.1 cm - height: 34.7 cm - weight: 5.7 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus BE229QLB 21.5 Bundle deal on Asus BE229QLB 21.5" 1920 x 1080 5ms VGA DVI Monitor
£232.98
CW2R StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
CW2R StarTech.com Articulating Monitor Arm In Stock £104.51
CW2R StarTech.com Dual Monitor Stand In Stock £70.92
CW2R StarTech.com Cubicle Monitor Hanger In Stock £45.76
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 100 - 150
