Product
Asus B1MR DLP WXGA Wireless Mobile Projector with Bag
Quicklinx: BN8YWS00 Mfr#: B1MR
The ASUS B1MR Ultra-bright Wireless LED Projector delivers incredibly bright, sharp visuals with native WXGA 1280 x 800 resolution, 900 lumens light output, and a 100% NTSC color scale to project precise, detailed color images. The B1MR features a mercury-free Eco-LED light source with a 30,000-hour lifespan to cut down on maintenance and bulb-replacement costs.
  • Bright, crisp projections
  • Compact portable Wi-Fi projector cuts the need for cables
    The ASUS B1MR features a small Wi-Fi adapter for a direct wireless connection to a notebook PC, or Android and iOS devices. This removes the need to carry a video cable solely for presentation use, and allows presentations, documents and multimedia files to be streamed to the B1MR wirelessly from elsewhere in a room. The B1MR with ASUS Wi-Fi Projection APP helps bring iOS and Adroid content from input device to the big screen, and also provides advanced "Split Screen Control", to allow user to choose two or four split screens.
  • Instant on and off
    The ASUS B1MR turns on in five seconds without having to warm up, and powers off without the need for a cooling-down period.
  • Auto Keystone Correction
    Whatever angle the B1MR is positioned, the Auto Keystone Correction detects and corrects to ensure a straight, rectangular shape.
  • Big screen at a short distance
    The B1MR has the best short throw ratio for you to project a 51-inch image from a distance of only 1 meter from the screen.
ASUS B1MR - DLP projector - portable - 3D
DLP projector
3D Capable
Brightness
900 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb type
RGB LED
Bulb life cycle
Up to 30000 hour(s)
Video Input
RGB, composite video - MPEG-4, AVI, WMV, MOV, MPG, MKV
Supported Memory Cards
SD Memory Card
Speakers
Speaker(s) - integrated
85 Watt
17.5 cm x 13.9 cm x 4.45 cm
900 g
DLP projector
3D Capable
Enclosure Colour
Projector
Brightness
900 lumens
Contrast Ratio
10000:1
Image Size
79.2 cm - 389 cm
Projection Distance
0.6 m - 3 m
Throw Ratio
0.9:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
RGB LED
Bulb life cycle
Up to 30000 hour(s)
Controls & Adjustments
Keystone correction
JPEG photo playback, MP3 playback, USB host function, DLP 3D Ready, 16:9 aspect ratio support, Wireless Ready, BMP photo playback, 16:10 aspect ratio support, PPT files support, XLS files support, PDF files support, 4:3 aspect ratio support, Mercury-free illumination technology, built-in foldable stand, WAV playback, WMA playback, AAC playback, ASUS SonicMaster, MP2 playback
Lens
Keystone Correction Type
Digital
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
SD Memory Card
Digital Video Format
Speakers
Integrated
Output Power / Channel
2 Watt
1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x composite video input - mini-phone 3.5 mm , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x headphones - mini-phone stereo 3.5 mm
Carrying case, remote control
1 x VGA cable
Security Features
UL, VCCI, C-Tick, CB, CCC, FCC, PSE Mark, GOST-R
Power Source
AC
85 Watt
Power Consumption Stand by
0.5 Watt
17.5 cm
13.9 cm
4.45 cm
900 g
20 - 90%
Sound Emission
32 dBA
28 dBA
