Asus B150M PRO GAMING Intel B150 S1151
Quicklinx: BM1JWS00 Mfr#: B150M PRO GAMING
Be the best on the battlefield with B150M Pro Gaming's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! ASUS SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable 115 dB signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected 5V power supply.
B150M Pro Gaming banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the ultimate networking technology, including tournament-level Intel Gigabit Ethernet and ASUS LANGuard to keep your connection fast, so fire first and watch your enemies fall. Protect your back in the game and let B150M Pro Gaming protect all sides in the real world! Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future. B150M Pro Gaming is built for play - strong enough storm through the industry's extremely punishing labs workouts. With B150M Pro Gaming you do more than just play - you'll experience gaming on the edge of reality.
  • Flawless audio that makes you part of the game
  • Shielded audio, superior sound with SupremeFX
  • Illuminated shielding
    Banish analog interference and enjoy eye-catching, customizable lighting effects.
  • EMI cover
    Effective shielding against electromagnetic interference preserves the integrity of audio signals for the ultimate quality.
  • Top-speed protected networking
  • Intel Gigabit Ethernet
    Featuring Intel Ethernet for faster, smoother gaming. Intel's LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay.
  • LANGuard for pumped-up throughput and surge protection
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Performance level up
    With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports amazing data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible.
  • FAN Xpert
    Via two 4/3 pin (PWM/DC) combo fan connectors and two onboard thermal sensors, Fan Xpert makes sure every fan achieves the optimum balance of cooling performance and low noise.
  • GPU Boost
    ASUS GPU Boost technology lets you accelerate B150M Pro Gaming integrated GPU (iGPU) for extreme graphics performance safely and easily via a user-friendly interface - it's a free iGPU level-up!
  • USB 3.0 Boost
    This great technology accelerates the already-fast speed of USB 3.0, enabling transfer speeds.
  • Gamer's guardian for real-world protection
  • DRAM overcurrent protection
    All connection ports and DRAM are protected against overcurrent and short-circuit damage by onboard resettable fuses, extending your motherboard's life.
  • Stainless steel back I/O
    Crafted from chromium-plated, corrosion-resistant stainless steel, the input/output (I/O) panel is three times longer than ordinary panels!
  • ESD protection for extended component lifespan
    Electrostatic discharge (ESD) could mean game over for your rig, so B150M Pro Gaming is protected by ESD Guards to actively prevent ESD - ensuring longer component lifespan and providing greater system resilience. Game on!
  • Audio connector
    Capacitor protection on both front and back audio-output circuits.
  • LAN connector
    ESD TVS diode protection and an anti-surge LAN connector protects against extreme events, such as lightning strikes.
  • USB 3.0/2.0 connectors
    On-circuit transient-voltage-suppression (TVS) diodes and capacitor protection for surface-mount and dual-inline packages.
  • Built for gaming
ASUS B150M PRO GAMING - motherboard - micro ATX - LGA1151 Socket - B150
Motherboard - micro ATX
Chipset Type
Intel B150
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600, 1 x M.2
USB / FireWire Ports
4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B150
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Graphics
1024 MB
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2
1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 4 x USB 2.0 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS Q-Shield, ASUS Fan Xpert, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, USB 3.0 Boost, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard, ASUS Gamer's Guardian
Cable ties, I/O back plate, cable labels, 1 x M.2 screw
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS EZ Flash 3
Plug and Play
23.4 cm
21.8 cm
