ROG STRIX-RX470-O4G-GAMING
ASUS ROG Strix RX 470 for brilliant HD gaming with Aura RGB Lighting
1270 MHz engine clock in OC mode for outstanding performance and gaming experience.
DirectCU II with Patented Wing-Blade 0dB Fan Design delivers maximum air flow with 30% cooler and 3X quieter performance.
ASUS FanConnect features 4-pin GPU-controlled header connected to system fans for optimal thermal performance.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
Aura RGB Lighting to express personalised gaming style.
GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly.
ROG Strix is the newest recruit into the Republic of Gamers. A series of specialised gaming gear designed for the rebel in all of us, Strix exemplifies ROG's premier performance, innovative technology, and leading quality, but with its own confident and dynamic attitude. Featuring bold designs and bright colors, this exciting new series possesses a spirit of fierce individualism that charges every gaming experience with thrilling energy. ROG Strix equips players with the necessary speed and agility to dominate their game. A new generation of force has arrived. Join the Republic and experience the power of ROG Strix.
OUTSHINE THE COMPETITION
ROG Strix RX 470 gaming graphics cards are packed with exclusive ASUS technologies, including DirectCU II Technology with Patented Wing-Blade Fans for up to 30% cooler and 3X quieter performance, and Industry-only Auto-Extreme Technology for premium quality and the best reliability. Aura RGB Lighting enables a gaming system personalisation. ROG Strix RX 470 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
Patented Triple Wing-Blade 0dB Fans
Max Air Flow with 105% More Air Pressure
DirectCU II features dual 0dB fans engineered with a patented wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games in complete silence and make DirectCU II the coolest and quietest graphics card in the market.
ASUS FanConnect
30% Cooler and 3X Quieter Performance
When gaming, GPU temperatures are often higher than CPU temps. However, chassis fans usually reference CPU temperatures only, which results in inefficient cooling of the system. For optimal thermal performance, ROG Strix RX 470 graphics cards feature a 4-pin GPU-controlled header that can be connected to system fan for targeted supplemental cooling.
Industry-only 100% Automated Production Process
All ASUS graphics cards are now produced using Auto-Extreme Technology, an industry-exclusive, 100% automated production process that incorporates premium materials to set a new standard of quality. Auto-Extreme Technology ensures consistent graphics card quality as well as improved performance and longevity. This new manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%.
5+1 Phase Super Alloy Power II
Enhanced Durability and Efficiency
ASUS engineers have integrated premium alloy components into their graphics card designs to reinforce overall reliability. Super Alloy Power II components greatly enhance efficiency, reduce power loss and achieve thermal levels that are approximately 50% cooler than previous designs.
Aura RGB Lighting
Where Style Meets Performance
Featuring Aura RGB Lighting on both the shroud, ROG Strix graphics cards are capable of displaying millions of colors and six different effects for a personalised gaming system.
Your Need for Speed, Fulfilled
The Best Combo Ultra-smooth Gameplay
AMD FreeSync™ technology resolves the communication issues between processor and monitor, eliminating image tears and choppiness for effortlessly smooth gameplay. With ROG Strix gaming graphics cards and ASUS MG gaming monitors, scenes appear instantly, objects look sharper, and gameplay is super smooth, giving you a stunning visual experience and a serious competitive edge.
DirectCU II technology with direct-GPU contact heatpipes
Exclusive DirectCU II cooling technology features direct-GPU contact heatpipes that transports more heat away from the GPU and outperform reference designs, achieving cooler gaming performance. -
Dual wing-blade 0 dB fans
DirectCU II features dual 0 dB fans engineered with a wing-blade design that delivers maximum air flow and improved static pressure over the heat sink, while operating at quieter volumes than reference cards. -
ASUS FanConnect
- ASUS ROG STRIX-RX470-O4G-GAMING - OC Edition - graphics card - Radeon RX 470 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 470
- Memory
- 4 GB GDDR5
- Core Clock
- 1270 MHz
- Effective Memory Clock
- 6.6 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 5120 x 2880
- HDMI , 2 x DVI-D , DisplayPort
- API Supported
- OpenGL 4.5
- 4.2 cm x 24.2 cm x 12.9 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 470
- Core Clock
- 1270 MHz
- Max Resolution
- 5120 x 2880
- API Supported
- OpenGL 4.5
- Native HDMI, FreeSync Technology, 5+1+1 Phase Power Design, Super Alloy Power II technology, AUTO-EXTREME technology, DirectCU III with Triple Wing-Blade 0dB Fan Design, ASUS FanConnect, Aura RGB Lighting, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.6 GHz
- Bus Width
- 256-bit
- Included Accessories
- 2 x cable ties
- Software Included
- Aura, display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (14 days Premium licence)
- 4.2 cm
- 24.2 cm
- 12.9 cm
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
