Asus AMD Radeon R5 230 625MHz 1GB DDR3 PCI-E VGA DVI HDMI
Quicklinx: B6VJWS00 Mfr#: R5230-SL-1GD3-L
Graphics Processor Manufacturer: AMD
Graphics Processor: AMD Radeon R5 230
Interface: PCI Express 2.1 x16
Memory Size: 1GB
Digital Output: Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
  • High-Definition Multimedia Interface (HDMI)
20 in stock
£33.05 ex VAT
£39.66 inc VAT
R5 230 is the fantastic graphics card from ASUS. Engineered with a highly-efficient 0 dB thermal design, it dissipates heat in complete silence - making R5 230 the perfect choice for your slim line home-theater PC (HTPC) build. Advanced EMI shielding reduces electromagnetic interference by up to 66% for a stable signal, pin-sharp images and safer and healthier computing.
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
  • Graphics galore for everyone!
  • Perfect for building a hushed HTPC
  • Clearer signals and safer usage
    ASUS reduces 66% of electromagnetic interference both given off and received by the card - resulting in a more stable signal, clearer screen display, and a safer, healthier computing environment.
  • Stream online instantly
    GPU tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games is played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
  • AMD HD3D
    Immerse in stereoscopic 3D gaming and get up close and personal with your favorite stars while watching Blu-ray 3D. AMD HD3D is also designed for professionals who create complex visual effects and detailed data visualizations.
  • DirectX 11
    DirectX 11 GPU-accelerated tessellation allows more detailed geometry to be packed into a scene, allowing characters to be rendered with cinema-quality detail.
ASUS R5230-SL-1GD3-L - graphics card - Radeon R5 230 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
1 GB DDR3
Core Clock
625 MHz
Effective Memory Clock
1.2 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11
Fanless
16.764 cm x 6.86 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - low profile - fanless
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
Core Clock
625 MHz
Max Resolution
2560 x 1600
API Supported
DirectX 11
Native HDMI, ASUS 0-dB thermal solution, Asus EMI Shield, AMD HD3D Technology, AMD CrossFireX Technology, GPU Tweak Streaming, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.2 GHz
Bus Width
64-bit
75 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
16.764 cm
6.86 cm
B6VJ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B6VJ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.55
B6VJ C2G 5m Select High Speed HDMI with Ethernet In Stock £22.11
B6VJ C2G 10m Select High Speed HDMI with Ethernet In Stock £42.46
B6VJ C2G 15m Select High Speed HDMI with Ethernet In Stock £56.92
B6VJ C2G Pro HDMI to VGA Converter In Stock £53.02
Memory Size: 1GB
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: Asus
Price Range Ex VAT: 0 - 50
