Asus AM1M-A AMD AM1 DDR3 mATX
Quicklinx: 9DT1WS00 Mfr#: AM1M-A
AMD AM1 Socket-based power-efficient SoC motherboard for entry-level desktops, featuring exclusive high-endurance 5X Protection
This powerful and innovative motherboard supports both dual- and quad-core AMD Athlon and Sempron SoC (system-on-a-chip) APUs integrating Radeon HD graphics and support for HD video playback. This revolutionary APU (Accelerated Processing Unit) combines high processing power, advanced Microsoft DirectX 11.1 graphics, and Fusion controller hubs (FCHs) in one small, efficient package. This SoC APU features up to single-channel DDR3 1600/1333 memory, SATA 6 Gbit/s and USB 3.0 natively. AMD Athlon/Sempron APUs are the first multi-core x86 SoC with AM1 series socket solution for entry-level desktops, improving performance by over 50 percent compared to the previous generation of AMD APUs.
  • ASUS 5X PROTECTION - All-round protection provides the best quality, reliability, and durability
  • New UEFI BIOS - Friendlier, easier, and more intuitive with helpful info added
  • USB 3.0 Boost (UASP Support) - 170% faster transfer speeds than traditional USB 3.0
  • Ai Suite 3 - One-stop access to innovative ASUS features
AMD SoC Athlon and Sempron Series APUs
This powerful and innovative motherboard supports both dual- and quad-core AMD Athlon and Sempron SoC (system-on-a-chip) APUs integrating Radeon™ HD graphics and support for HD video playback. This revolutionary APU (Accelerated Processing Unit) combines high processing power, advanced Microsoft® DirectX 11.1 graphics, and Fusion controller hubs (FCHs) in one small, efficient package. This SoC APU features up to single-channel DDR3 1600/1333 memory, SATA 6Gbit/s and USB 3.0 natively. AMD Athlon/Sempron APUs are the first multi-core x86 SoC with AM1 Series socket solution for entry-level desktops, improving performance by over 50 percent compared to the previous (`Brazos 2.0') generation of AMD APUs.
ASUS 5X Protection: All-round protection provides the best quality, reliability, and durability
ASUS motherboards guard your PC with 5X Protection. We use quality components like DIGI+ VRM digital power design for precise APU power on demand, ESD units tested to strict standards that eliminate electrostatic interference, and resettable fuses around DRAM slots to prevent overcurrent and short-circuit damage. We also use corrosion-resistant back I/O shields, all examples of ASUS providing the best possible reliability and durability.
  • ASUS 5x protection - all-round protection provides the best quality, reliability, and durability
    ASUS motherboards guard your PC with 5x protection. ASUS uses quality components like DIGI+ VRM digital power design for precise APU power on demand, ESD units tested to strict standards that eliminate electrostatic interference, and resettable fuses around DRAM slots to prevent overcurrent and short-circuit damage.
  • UEFI BIOS - friendlier and more intuitive - exclusive EZ mode adds useful info to become even easier
    Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and now features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports. EZ mode has a whole look, upgraded with extra-friendly capabilities like detailed fan controls, D.O.C.P profile settings, SATA information, and fast clock adjustment. Together, these perfect your BIOS experience.
  • USB 3.0 Boost - 170% faster transfer speeds than traditional USB 3.0
    ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) in Windows 8.1/8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. ASUS software automatically accelerates data rates for compatible USB 3.0 peripherals without any user interaction.
  • Q-Slot - effortless PCI Express component removal
    Press the Q-Slot clip lightly, and graphics cards just pop out. The large winged clip is easy to reach so you don't have to struggle with installing or removing even the biggest graphics cards.
  • ASUS boot setting - multiple startup options
    Thanks to ASUS Windows 8 hardware optimization, ASUS boot setting provides better flexibility in customizing your PC's startup process. You can shorten system boot-up time to 2-seconds for a smoother user experience under Windows 8, and even previous versions of Windows. Also, you can enter the BIOS directly with one click through a user-friendly interface, and quickly select your preferred system boot up method: either get to the OS in seconds or opt for regular boot up. Whatever your choice, settings are saved and persistent, with no need to choose every time you power on.
  • AI Suite 3 - one-stop access to innovative ASUS features
    ASUS AI Suite 3 offers a brand user experience through a clearer and more attractive interface with support for larger monitors. It consolidates all exclusive ASUS features into one simple-to-use package, allowing you to supervise overclocking, energy consumption, fan speeds, voltages and more. This all-in-one app offers diverse and easy to use functionality, with no need to switch back and forth between different utilities.
  • Multi-GPU/monitors - discover future visual experiences
    Following up on popular 1080p Full HD, 4K Ultra HD is the next big thing, and you're ready for the upgrade thanks to integrated graphics that support up to 4096 x 2160 displays via HDMI. That's four times the pixel count of 1080p (1920 x 1080), offering incredible visual clarity, detail, and realism.
ASUS AM1M-A - motherboard - micro ATX - Socket AM1
Motherboard - micro ATX
Processor Socket
1 x Socket AM1
Compatible Processors
Athlon, Sempron (supports CPUs with up to 4 cores)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Processor Socket
Socket AM1
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
AMD Memory Profile (AMP)
Audio
Audio Codec
Realtek ALC887-VD
High Definition Audio
LAN
Network Controller
Realtek RTL8111GR
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x HDMI
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x parallel - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, UEFI BIOS
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS DIGI+ VRM, USB 3.0 Boost, Disk Unlocker, AMD Memory Profile (AMP) support, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, ASUS Boot Setting, ASUS Stainless Steel Back I/O
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger+, ASUS Update, ASUS AI Suite III
Plug and Play, ACPI 2.0a, ErP Ready
22.6 cm
17 cm
