The ASUS All-in-One PC A6420 is powered by the Intel 4th generation Core processor with DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do.
The ASUSPRO A6420 Series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A6420 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses. With HDMI-out ports, A6420 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality.
Faster, more powerful and more efficient
The ASUS All-in-One PC A6420 is powered by the Intel 4th generation Core processor with DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do. -
NVIDIA Graphics for optimized video experience
Armed with a powerful NVIDIA GT930M graphics card with 1GB VRAM which provides excellent audio experiences for customers. The A6420 Series also features 802.11 ac/g/n Wi-Fi + BT 4.0 and an integrated VGA and HDMI ports to keep you connected to external monitor and displays. -
Upgrade your business
Windows 10 is ready for small or mid-size business - helping you do more with enhanced data protection and a hosted remote connection to your PC or your corporate or school network. -
Convenient connectivity with COM port, USB 3.0, VGA and HDMI port
The ASUSPRO A6420 Series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A6420 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses. With HDMI-out ports, A6420 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality. -
User-upgradable storage and memory via tool-less rear cover
The ASUSPRO A6420 series features a specially-designed tool-less rear cover. This allows users to upgrade the AiO's storage and memory themselves in a matter of seconds, making A6420 both flexible and future-proof, with users able to add extra storage and memory when needed. -
Built-in smart card reader
AASUSPRO A6420 All-in-One PC features an optional built-in smart card reader, saving you the space of using an external smart card reader. The built-in smart card reader allows your All-in-One PC to support smart card applications such as data access, user identification, payment and others.
- ASUS All-in-One PC A6420 - all-in-one - Core i5 4460S 2.9 GHz - 4 GB - HDD 1 TB - LED 21.5"
- Personal computer - all-in-one
- Processor
- Intel Core i5 (4th Gen) 4460S / 2.9 GHz (, up to 3.4 GHz, (Quad-Core)
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 6 in 1
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 4600
- Camera
- Audio Output
- Stereo
- Networking
- GigE, Bluetooth 4.0, Wi-Fi
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition
- Black
- 51.96 cm x 17.406 cm x 37.95 cm
- 9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- All-in-one
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
- Dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- 6 in 1 card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 1 Megapixel
Audio Input
- Microphone
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth 4.0, Wi-Fi
- Bays
- Internal 3.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin
- 4 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x LAN (Gigabit Ethernet) , 1 x VGA output , 1 x HDMI output , 2 x USB 2.0 , 1 x serial
- Theft/Intrusion Protection
- UL, C-Tick, BSMI, CCC, FCC, CECP
- Power adapter
- Power Provided
- 120 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 51.96 cm
- 17.406 cm
- 37.95 cm
- 9 kg
