Asus A6420-BC003E i3-4170 4GB 500GB Windows 7 Pro 21.5" AIO
Quicklinx: BYYWWS00 Mfr#: A6420-BC003E
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
The ASUS All-in-One PC A6420 is powered by the Intel 4th generation Core processor with DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do.
The ASUSPRO A6420 series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A6420 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. With HDMI-out ports, A6420 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality.
  • Faster, more powerful and more efficient
    The ASUS All-in-One PC A6420 is powered by the Intel Core processor with DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do.
  • NVIDIA graphics for optimized video experience
    Armed with a powerful NVIDIA GT930M graphics card with 1 GB VRAM which provides excellent audio experiences for customers. The A6420 Series also features 802.11 ac/g/n Wi-Fi + BT 4.0 and an integrated VGA and HDMI ports to keep you connected to external monitor and displays.
  • Upgrade your business
    Windows 10 is ready for small or mid-size business - helping you do more with enhanced data protection and a hosted remote connection to your PC or your corporate or school network.
  • Convenient connectivity with COM port, USB 3.0, VGA and HDMI port
    The ASUSPRO A6420 Series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A6420 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses. With HDMI-out ports, A6420 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality.
  • User-upgradable storage and memory via tool-less rear cover
    The ASUSPRO A6420 series features a specially-designed tool-less rear cover. This allows users to upgrade the AiO's storage and memory themselves in a matter of seconds, making A6420 both flexible and future-proof, with users able to add extra storage and memory when needed.
  • Built-in smart card reader
    AASUSPRO A6420 All-in-One PC features an optional built-in smart card reader, saving you the space of using an external smart card reader. The built-in smart card reader allows your All-in-One PC to support smart card applications such as data access, user identification, payment and others.
ASUS All-in-One PC A6420 - all-in-one - Core i3 4170 3.7 GHz - 4 GB - HDD 500 GB - LED 21.5"
Personal computer - all-in-one
Intel Core i3 (4th Gen) 4170 / 3.7 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA
Optical Storage
DVD SuperMulti
Card Reader
6 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
NVIDIA GeForce 930M
Video Memory
1 GB
Camera
Audio Output
Stereo
GigE, 802.11b/g/n, Bluetooth 4.0
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
51.96 cm x 17.406 cm x 37.95 cm
8.37 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
All-in-one
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Dual channel memory architecture
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
6 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Graphics Controller
Graphics Processor
NVIDIA GeForce 930M
Video Memory
1 GB
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
1 Megapixel
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Bays
Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
4 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x LAN (Gigabit Ethernet) , 1 x VGA output , 1 x HDMI output , 2 x USB 2.0 , 1 x serial
Theft/Intrusion Protection
UL, C-Tick, BSMI, CCC, FCC, CECP
Power adapter
Power Provided
120 Watt
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Sustainability Information
ENERGY STAR Certified
51.96 cm
17.406 cm
37.95 cm
8.37 kg
BYYW C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
BYYW C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
