Enhanced Productivity! Upgraded Performance to Do More Faster, more powerful and more efficient The ASUS All-in-One PC A4320 is powered by the Intel 4th generation Core processor with support for up to 16GB of DDR3 memory for easy multitasking, enhanced performance, and better energy efficiency in whatever you choose to do. Latest NVIDIA Graphics for Optimized Video Experience Armed with a powerful NVIDIA GT930M graphics card with 1GB VRAM which provides excellent audio experiences for our customers. Upgrade Your Business Windows 10 is ready for small or mid-size business helping you do more with enhanced data protection and a hosted remote connection to your PC or your corporate or school network. Windows 10 enables businesses to be more productive by simplifying management and deployment and helping to protect corporate data better than ever. Convenient Expandability Full connectivity with upgradable flexibility Convenient connectivity with COM port, USB 3.0, VGA and HDMI port The ASUSPRO A4320 Series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A4320 can easily connect to other commercial devices from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage ideal for ever-expanding businesses. With HDMI-out ports, A4320 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality.
The ASUSPRO A4320 Series is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports and VGA port, the A4320 can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses. With HDMI-out ports, A4320 Series provides uncompressed digital video and audio quality, enabling the transmission of High-Definition audiovisual contents, allowing you to present your files at the best quality. -
User-upgradable storage and memory via tool-less rear cover
The ASUSPRO A4320 series features a specially-designed tool-less rear cover. This allows users to upgrade the AiO's storage and memory themselves in a matter of seconds, making A4320 both flexible and future-proof, with users able to add extra storage and memory when needed.
- ASUS All-in-One PC A4320 - all-in-one - Pentium G3260 3.3 GHz - 4 GB - HDD 500 GB - LED 19.5"
- Personal computer - all-in-one
- Processor
- Intel Pentium G3260 / 3.3 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s
- Optical Storage
- DVD SuperMulti
- Card Reader
- 6 in 1
- Monitor
- 19.5" - LED - 1600 x 900 (HD+) - 16:9
- Graphics Controller
- Intel HD Graphics
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0
- OS Provided
- Microsoft Windows 7 Professional (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Black
- 47.7 cm x 17.406 cm x 37.115 cm
- 7.38 kg
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- All-in-one
- Black
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- 6 in 1 card reader
- Supported Flash Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED
- Diagonal Size
- 19.5"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Image Aspect Ratio
- 16:9
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 1 Megapixel
Audio Input
- Microphone
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- 2 x USB 2.0 , 1 x VGA output , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 4 x USB 3.0 , 1 x serial
- Theft/Intrusion Protection
- VESA Mounting Interface
- UL, C-Tick, BSMI, CB, CCC, CECP
- Power adapter
- Power Provided
- 120 Watt
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- ENERGY STAR Certified
- 47.7 cm
- 17.406 cm
- 37.115 cm
- 7.38 kg
