Asus A4110-BD027M N3150 4GB 500GB 15.6" AIO
Quicklinx: BYYZWS00 Mfr#: A4110-BD027M
  • Celeron
This ASUS All-in-One PC A4110 series is powered by the advanced processor and memory, so it delivers easy multitasking and enhanced performance. The model is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports, VGA port and HDMI-out, it can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses. And the featured NFC technology allows you to simply tap your NFC-enabled device to your A4110 All-in-One PC to transfer files and information, providing a simple way to download information at information centers, mobile payments at retail shops or acquire digital coupon from a digital signage or kiosk.
  • Smart performance
  • Convenient connectivity
    The A4110 is designed for convenient connectivity, equipped with COM ports, USB 3.0 ports, VGA port and HDMI-out, it can easily connect to other commercial devices - from projectors at school to barcode readers and POS systems at retail. The additional COM port supports a wide variety of devices, allowing more flexible usage - ideal for ever-expanding businesses.
  • Password-free access
    With only one tap, instantly log in to the system without having to key in your password. This is suitable for returning or borrowing software at libraries or membership logon at chain stores.
  • Information sync-up
  • Work at your fingertips
    This PC with full 10-finger capacitive multi-touch capability offers sensitive and smooth touch experience for users to enjoy fast response with easily touch of the fingertip. Less pressure extends the reliability of the touch panel. 10-point touch solution enlarges the possibilities of POS demand, educational and other operating purposes.
  • Easily set up password protection for your data with UEFI BIOS
    UEFI BIOS not only provides a mouse-controlled interface that enables more flexible and convenient input, but also combines system management tools like drive password protection and USB ports and card reader activation. A user-friendly user interface offers easier system tweaking and greater storage support.
  • Fanless design
    The model features a fanless design, giving users a quiet work space by eliminating the ambient noises caused by internal fans. This approach also decreases power consumption, and improves system reliability by avoiding potential dirt-related component failures.
ASUSPRO A4110 - all-in-one - Celeron N3050 1.6 GHz - 4 GB - HDD 500 GB - LED 15.6"
Personal computer - all-in-one
Intel Celeron N3050 / 1.6 GHz (, up to 2.16 GHz, (Dual-Core)
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
No optical drive
Card Reader
6 in 1
Monitor
15.6" - LED - 1366 x 768 (HD) - 16:9 - touchscreen
Graphics Controller
Intel HD Graphics
Audio Output
Stereo
GigE, Wi-Fi
OS Provided
No operating system
37.75 cm x 2.85 cm x 24.7 cm
2 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
All-in-one
Processor / Chipset
CPU
Intel Celeron N3050
Clock Speed
1.6 GHz
Max Turbo Speed
2.16 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 8 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
15.6"
Native Resolution
1366 x 768 (HD)
Widescreen Display
Image Aspect Ratio
16:9
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA, HDMI
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Camera
Resolution (MP)
1 Megapixel
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Audio Input
Microphone
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Wi-Fi
Bays
Internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x SO-DIMM 204-pin
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x LAN (Gigabit Ethernet) , 1 x VGA output , 1 x HDMI output , 2 x USB 2.0 , 2 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, VCCI, BSMI, CB, CCC, FCC
Power adapter
Power Provided
45 Watt
Operating System / Software
OS Provided
No operating system
Sustainability Information
ENERGY STAR Certified
37.75 cm
2.85 cm
24.7 cm
2 kg
