ROG G20 is designed to dominate the small form factor gaming desktop segment. G20 features a compact 12.5-liter case that houses a powerful processor and an amazing graphics card to give you unstoppable performance for games and home entertainment in WQHD quality.
G20 is designed with no visible exterior side exhaust vents. G20 has a thermal design that takes advantage of natural convection, with a hidden airflow channel that ensures efficient heat management for marathon gaming sessions. On top of that, it runs silently at just 22 dB at idle.
On the outside, G20 sports a bold design - boasting a matte-black finish, aggressive lines, Mayan-inspired markings and customizable lighting effects showcase up to 8 million colors.
Versatility in a 12.5-liter case
A one-stop gaming and entertainment system, ROG G20 is set to dominate the small form factor gaming desktop segment. Despite its 12.5-liter size, G20 packs quite a punch, giving you the performance you'd expect from a hardcore gaming system at a fraction of the size. -
Ultra-quiet
G20 isn't just powerful, it's extremely quiet as well. You won't be disturbed when you leave G20 on overnight to download games, as It runs whisper-quiet at just 22 dB at idle - more quiet than a typical library. -
Customizable lighting effects with 8 million colors
ROG G20 has a bold design that features a matte-black finish, aggressive lines and Mayan-inspired markings. Customizable lighting effects showcase up to 8 million colors across the chassis, reflecting the feel of any game you're playing to take your gaming experience to a whole new level. -
Mind-blowing sound with SonicMaster-optimized gaming audio
Immersive visuals aside, the best gaming desktops take your gaming experiences further through audio. Through a unique mix of hardware and audio tuning software, SonicMaster brings you right into the fight. Gunshots ring out, explosions reverberate and even footsteps become auditory cues on the digital battlefield. Be immersed in battle whether you're using a headset or speakers. ROG AudioWizard sound processing provides ROG desktops with an additional layer of audio enhancement, with up to five customizable modes you can easily switch on-the-fly. -
Effective heat management for ultimate stability
ROG G20 is designed with no visible exterior side exhaust vents in order to keep the chassis' neat, clean lines. ROG G20 has a thermal design that takes advantage of natural convection, with a hidden airflow channel that ensures efficient heat management. Two internal fans further enhance heat dissipation, making ROG G20 ideal for marathon gaming sessions.
- ASUS ROG G20CB-UK011T - SFF - Core i7 6700 3.4 GHz - 8 GB - SSD 128 GB, HDD 2 TB
- Personal computer - small form factor - 2 x power adapters (230W+180W)
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Hard Drive (2nd)
- HDD 2 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- NVIDIA GeForce GTX 960
- Video Memory
- 2 GB
- Gaming
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
- OS Provided
- Windows 10 Home 64-bit Edition
- Software Included
- ROG AudioWizard
- 10.4 cm x 35.8 cm x 34 cm
- 6.38 kg
- Personal computer
- Product Form Factor
- Small form factor
- Gaming
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H170
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Hard Drive (2nd)
- HDD
- Interface Class
- Serial ATA
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 2 GB
- Video Interfaces
- DVI, HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 2.5" x 1/8H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x PCIe x16
- 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x HDMI output , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 2 x USB 3.1 , 1 x DVI , 3 x DisplayPort
- Power adapter
Operating System / Software
- OS Provided
- Software
- ROG AudioWizard
- 10.4 cm
- 35.8 cm
- 34 cm
- 6.38 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
