Asus  ROG G20CB Gaming PC i7-6700, GTX960 2GB, 8GB, 2TB + 128GB S
Quicklinx: BW9PWS00 Mfr#: G20CB-UK011T
  • Core i7
  • NVIDIA GeForce GTX 960
  • IEEE 802.11n
ROG G20 is designed to dominate the small form factor gaming desktop segment. G20 features a compact 12.5-liter case that houses a powerful processor and an amazing graphics card to give you unstoppable performance for games and home entertainment in WQHD quality.
G20 is designed with no visible exterior side exhaust vents. G20 has a thermal design that takes advantage of natural convection, with a hidden airflow channel that ensures efficient heat management for marathon gaming sessions. On top of that, it runs silently at just 22 dB at idle.
On the outside, G20 sports a bold design - boasting a matte-black finish, aggressive lines, Mayan-inspired markings and customizable lighting effects showcase up to 8 million colors.
  • Versatility in a 12.5-liter case
    A one-stop gaming and entertainment system, ROG G20 is set to dominate the small form factor gaming desktop segment. Despite its 12.5-liter size, G20 packs quite a punch, giving you the performance you'd expect from a hardcore gaming system at a fraction of the size.
  • Ultra-quiet
    G20 isn't just powerful, it's extremely quiet as well. You won't be disturbed when you leave G20 on overnight to download games, as It runs whisper-quiet at just 22 dB at idle - more quiet than a typical library.
  • Customizable lighting effects with 8 million colors
    ROG G20 has a bold design that features a matte-black finish, aggressive lines and Mayan-inspired markings. Customizable lighting effects showcase up to 8 million colors across the chassis, reflecting the feel of any game you're playing to take your gaming experience to a whole new level.
  • Mind-blowing sound with SonicMaster-optimized gaming audio
    Immersive visuals aside, the best gaming desktops take your gaming experiences further through audio. Through a unique mix of hardware and audio tuning software, SonicMaster brings you right into the fight. Gunshots ring out, explosions reverberate and even footsteps become auditory cues on the digital battlefield. Be immersed in battle whether you're using a headset or speakers. ROG AudioWizard sound processing provides ROG desktops with an additional layer of audio enhancement, with up to five customizable modes you can easily switch on-the-fly.
  • Effective heat management for ultimate stability
    ROG G20 is designed with no visible exterior side exhaust vents in order to keep the chassis' neat, clean lines. ROG G20 has a thermal design that takes advantage of natural convection, with a hidden airflow channel that ensures efficient heat management. Two internal fans further enhance heat dissipation, making ROG G20 ideal for marathon gaming sessions.
ASUS ROG G20CB-UK011T - SFF - Core i7 6700 3.4 GHz - 8 GB - SSD 128 GB, HDD 2 TB
Personal computer - small form factor - 2 x power adapters (230W+180W)
Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s
Hard Drive (2nd)
HDD 2 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Video Memory
2 GB
Gaming
GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
OS Provided
Windows 10 Home 64-bit Edition
Software Included
ROG AudioWizard
10.4 cm x 35.8 cm x 34 cm
6.38 kg
Personal computer
Product Form Factor
Small form factor
Gaming
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H170
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA 6Gb/s
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
3
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
2 GB
Video Interfaces
DVI, HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 0 (free) x external 5.25" Slim Line
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x PCIe x16
1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 2 x HDMI output , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 2 x USB 3.1 , 1 x DVI , 3 x DisplayPort
Power adapter
Operating System / Software
OS Provided
Software
ROG AudioWizard
10.4 cm
35.8 cm
34 cm
6.38 kg
BW9P C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
