Your basket is empty
ASRock Z97 Pro3 Intel LGA1150 Z97 ATX RAID DDR3 Gigabit LAN USB 3.0
Quicklinx: B5Y0WS00 Mfr#: Z97 Pro3
The alloy chokes effectively increase up to 90% saturation current and feature a highly magnetic and heat resistant design, making the motherboard more efficient, stable and reliable.
The NexFET MOSFETs control the power supply to DRAM slots more efficiently. They provide lower RDS (on) 2.9 mO, delivering higher efficiency and lower temperature.
ASRock Z97 Pro3 - motherboard - ATX - LGA1150 Socket - Z97
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Xeon, Core i5, Core i3, Core i7 (supports 5th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1792 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2400 MHz (O.C.), 2133 MHz (O.C.), 1866 MHz (O.C.), 3100 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1792 MB
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Premium Blu-ray audio support
LAN
Network Controller
Intel I218V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 (x16 mode) , 3 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Rapid Storage Technology
1 x PS/2 keyboard / mouse , 2 x USB 2.0 , 4 x USB 3.0 , 1 x HDMI , 1 x VGA , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
2 x USB 3.0 - header , 4 x USB 2.0 - header , 1 x serial - header , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
Multilingual BIOS, SMBIOS 2.3.1. support, ACPI 1.1 support, UEFI BIOS
Manual Settings
Processor core voltage, memory voltage
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage, power supply fan tachometer
Sleep / Wake Up
Wake on LAN (WOL), Intel Remote Wake Technology
Hardware Features
ASRock Instant Flash, ASRock APP Charger, Intel Turbo Boost Technology 2.0, ASRock XFast LAN, ASRock XFast RAM, ASRock Crashless BIOS, ASRock OMG (Online Management Guard), ASRock Internet Flash, Digi Power Design, ASRock Dehumidifier Function, ASRock Restart to UEFI, ASRock UEFI System Browser, Energy Efficient Ethernet 802.3az, Preboot eXecution Environment (PXE), ASRock UEFI Tech Service, ASRock Easy Driver Installer, ASRock USB Key, Supports Intel K-Series unlocked CPU, ASRock BCLK, Premium Alloy Chokes (PAC), NexFET, ELNA Audio Capacitors, ASRock A-Tuning, ASRock Full Spike Protection, ASRock Cloud, ASRock APP Shop, ASRock Full HD UEFI, ASRock My Favorites in UEFI, ASRock UEFI Guide, ASRock Easy RAID Installer, Sapphire Black PCB
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, Antivirus (Trial version), Start8 (30 days trial), Google Chrome Browser, Google ChromeToolbar, Orbweb.ME Professional, ASRock Disk Health Report
WHQL, FCC, ACPI 1.1, EuP Ready, ErP Ready
